Calculate inductance of coils in CST Microwave
bluechips
Newbie level 5
Hi all,
I am designing a wireless power transfer system of two coils. The first one (Tx-coil, PORT 1) is a 1-turn coil and the second one (Rx-coil, PORT 2) is a 7-turn helical coil. In the post-processing section, I can extract the value of the inductance of the first coil, but I wanna also obtain the inductance value of the second coil. How can I do it? Thank you so much!
in your CST simulation, your data for second coil will be in S(2,2). Z(2,2) also will be available so you can insert equation to get your L(2,2).
Thank you, pragash. How can I insert the question to get L(2,2) in the post-processing part of CST?
hi bluechips,
honestly i have not done that in CST and i dont aware if CST have such capabilities. if i were you, i will export the touchstone file from CST to ADS and simulate SNP data. you can insert equation in keysight ADS without any problem.
