+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 5
    Points: 1,053, Level: 7
    Join Date
    Mar 2013
    Karur
    Posts
    94
    Points
    1,053
    Level
    7
    [Moved] Select PID Temperature controller Programming
    Dear all,
    Recently I have purchased Selec PID temperature module(PID500-000) for my application. Basic program I have done and its working good. Now I want to disable the Temperature module after 20 Minutes. It should maintain the temperature upto 20 min only. After that burner should not get an. I can not reach selec customer care. If anyone knows kindly help me out
    •   Alt23rd April 2016, 07:34
      advertising
  2. #2
    Super Moderator
    Points: 239,577, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,510
    Points
    239,577
    Level
    100
    Re: [Moved] Select PID Temperature controller Programming
    PID500 doesn't seem to provide the intended temperature programming function, only basic temperature ramp. You can either use a profile temperature controller like PR502 or add a separate electronic timer that shuts down the heater after 20 minutes.
