+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 3
    Points: 2,291, Level: 11
    Achievements:
    7 years registered
    Join Date
    Apr 2009
    Posts
    173
    Points
    2,291
    Level
    11
    [HELP] Grounded Co-Planar Wave guide Port Excitation in HFSS ??
    Hi Members
    I am trying to excite a simple patch antenna using Grounded Co-Planar Wave guide Structure (GCPW) by the techniques shown below in Fig.1.
    I do so but receive the error of "Port 1 is assigned to an internal face".
    Can someone kindly assist me in assigning wave guide port to the GCPW structure in HFSS simulator. I have included my design snaps as well for clarifications.
    Click image for larger version.
    Awaiting your replies;
    Regards
    •   Alt11th April 2016, 08:49
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,008, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    944
    Points
    6,008
    Level
    18
    Re: [HELP] Grounded Co-Planar Wave guide Port Excitation in HFSS ??
    Hi kela3kela,
    Comparing your two figures, it appears that your waveport is inside your vacuum box, which isn't allowed.
    You can either:
    a) change the wave port to a lumped port, in which case you need to know the characteristic impedance of the waveguide ahead of time, or
    b) Let the structure and the wave port touch the outer vacuum box boundary by moving the vacuum box's negative-y face to the same plane as the port. The wave port will override a radiation boundary.
    I generally would go with b.
    1 members found this post helpful.
    •   Alt11th April 2016, 15:30
      advertising
  3. #3
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    Apr 2009
    Posts
    173
    Points
    2,291
    Level
    11
    @planarMatamaterials: Thnx for ur advise. I will also implement option (b) and see if this helps.
    •   Alt11th April 2016, 16:15
      advertising
  4. #4
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    Apr 2009
    Posts
    173
    Points
    2,291
    Level
    11
    @planar: Thnx. Ur option helped.
