which gsm mobile sets are there which have inbuilt modems
rupeshsaxena2508
Newbie level 1
nokiaaud
sir,
i want to make my final year project in which i need to control a gsm mobile/ modem with a microcontroller 8051 series . kindly help me out at the earliest
1: which gsm mobile handset shd i use to recieve the AT commands.
2: some idea regarding interfacing with the phone using microcontroller.
i m a resident of INDIA . so help me out in the way so that i can get the mobile phones easily here.
Added after 2 minutes:
which mobile handsets have inbuilt modems
Re: which gsm mobile sets are there which have inbuilt modem
hi
erricson T-28 siemens A35 i never know about nokia but erricson and siemens support AT commands also have look to these post
and must take look to this topic
Nokia don't have AT command set except AT*NokiaTEST, AT*NokiaAUD and AT*NokiaFBUS. If you want to build a software tool use the Nokia PC Connectivity SDK (only Windows) which is based on several protocols: see examples of F2Bus and Nokia IR.
Added after 11 minutes:
Here you have Siemens AT command
if you need a Specific Brand just tell me and i will provide you it if i have
Mitsubishi Trium Astral , Mitsubishi Trium Aria,have modem which support AT commands in Text mode ,most ot the gsm use PDU mode example www.dreamfabric.com/sms
