+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Newbie level 3
    Points: 78, Level: 1
    Join Date
    Apr 2016
    Posts
    Points
    78
    Level
    LDO Regulator Circuit
    Hello. I'm an ECE student. I would like to ask anyone here who can give LDO circuit with the parameters of 0.3V-5V input and 8mA outpu current. Thank You.
  2. #2
    Administrator
    Points: 69,113, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    Re: LDO Regulator Circuit
    Your specification is incomplete and unclear.
    What is the required output voltage? Is a variable output range as well?
    Even an LDO linear regulator has a minimum dropout voltage, an input voltage of only 0.3 volts would like NOT be sufficient for voltage regulation except for a few millivolts output.
    BigDog
    The Edge... there is no honest way to explain it, because the only people who really know where it is are the ones who have gone over.
    -- Hunter S. Thompson
    •   Alt1st April 2016, 04:26
      advertising
  3. #3
    Advanced Member level 1
    Points: 2,426, Level: 11
    Join Date
    Mar 2015
    Posts
    476
    Points
    2,426
    Level
    11
    As far as your input voltage level is concern you will be able to generate 3.3 volt. Is that is your required voltage level?
    --Hobbyckts--
    Nothing you will loose by pressing "Helped Me" button instead conveying thanks.... But press only when the post helped you....
  4. #4
    Newbie level 3
    Join Date
    Apr 2016
    Posts
    Points
    78
    Level
    Thank You for the response. That's what our professor gave us. Can you give me LDO circuit?
    •   Alt1st April 2016, 15:51
      advertising
  5. #5
    Super Moderator
    Points: 55,084, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,144
    Points
    55,084
    Level
    57
    you should ask your professor about output voltage.
    There are thousands of LDO ready to buy.
    You want to use one of these IC´s and build the necessary circuit around the IC?
    Or do you want to develop your own LDO circuit? (With reference, error amplifier, power stage and so on)
    Klaus
  6. #6
    Administrator
    Achievements:
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    I would also suggest you reconfirm the input voltage range of 0.3 to 5.0 volts as the lower range limit of 0.3 volts is not particularly reasonable for most applications.
    BigDog
  7. #7
    Advanced Member level 5
    Points: 13,065, Level: 27
    schmitt trigger's Avatar
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,205
    Points
    13,065
    Level
    27
    I second the motion of the input voltage range.....0.3 volt input is absolutely unreasonable. How much will your output be, 0.25 volt?
    What are you powering with such a low voltage?
    I'm going to chime in a personal anecdote:
    When I was an EE student, I also had an electronics professor that would give us an assignment of, let's say, a 4 transistor amplifier, and ask us to fully analyze its DC-bias point. This was in pre-SPICE days, one had to calculate it manually.
    Where an NPN transistor was supposed to be, he had actually drawn a PNP.
    Most of the class assumed it was a typo, although the transistor part number was indeed for a PNP transistor, and proceeded to analyze the circuit -as is.
    Only a friend and myself wrote a note on the analysis: "as drawn the circuit can't work, however, if its replaced by a NPN, the bias points are..."
    Needless to say, the professor flunked everybody, EXCEPT my friend and myself. He then admonished us: "In your professional career, if you find a specification, a device, or a value that doesn't make sense...it doesn't matter from where or from whom is coming from, QUESTION IT!"
    That has been one of the most valuable pieces of advice I have ever received.
    My batteries are recharged by "Helpful Post" ratings.
    If you feel that I've helped you, please indicate it as a Helpful Post
    2 members found this post helpful.
    •   Alt2nd April 2016, 22:10
      advertising
  8. #8
    Advanced Member level 3
    Points: 5,529, Level: 17
    Join Date
    Dec 2015
    Madrid, Spain
    Posts
    994
    Points
    5,529
    Level
    17
    Quote Originally Posted by schmitt trigger View Post
    And that is the way to do it. Always put theoretical analysis by hand first, and then with simulation correct yourself. These days, I find it wrong to let those kids in maths classes calculate with a calculator instead by head.. and professor that allows them...
  9. #9
    Join Date
    Mar 2015
    Posts
    476
    Points
    2,426
    Level
    11
    Quote Originally Posted by CataM View Post
    Due to the technology all these things were started happening. In One case it shows our whereas in other it is making us lazy . There are seriously so many shorter ways available through which we can start doing calculation at the speed of almost to calculator which I leaned from my professors... Missing those Good old days..
    --Hobbyckts--
