+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 39
  1. #1
    Member level 5
    Points: 670, Level: 5
    Join Date
    Jun 2015
    Posts
    83
    Points
    670
    Level
    How to clear memory in mikrocontroller
    some time i startup my pic 16f876a it work without follow the instruction! I used serial port to send data to it and some time it repeat about 3 times. please help my knowledge is limited.
    •   Alt27th March 2016, 07:00
      advertising
  2. #2
    Advanced Member level 3
    Points: 3,996, Level: 14
    Join Date
    Aug 2015
    Posts
    773
    Points
    3,996
    Level
    14
    Re: How to clear memory in mikrocontroller
    Maybe you have enabled WDT (Watch Dog Timer) but not clearing the WDT and maybe this is causing the PIC to reset and restart repeatedly and causing the Serial printing to be done more than one time or maybe stack is overflowing and causing the PIC to reset and restart.
  3. #3
    Member level 5
    Join Date
    Jun 2015
    Posts
    83
    Points
    670
    Level
    I don't know exactly but this is my code:
    char  receive[64] ;
    void main(){
    int x;
    int i=0;
    TRISA=0X00;
    TRISB=0XFF;
    TRISC=0X80;
    PORTC=0X00;
    PORTA=0X00;
    PORTB=0X00;
    UART1_INIT(9600);
    delay_ms(100);
    while(1){
    if(Uart1_data_ready()==1){
    uart1_read_text(receive,'F',65);
    for(i=0;i<64;i++){
      switch(receive[i]){
          case'1': x=1; break;
          case'0': x=0; break;
     PORTA=x;
     delay_ms(50);
     PORTA=0X00;
     delay_ms(50);
       uart1_write('F');
    } // end if
    }  // end while
    }// end main
  4. #4
    Super Moderator
    Points: 241,624, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,962
    Points
    241,624
    Level
    100
    Means exactly what?
    read1_uart_text() may be waiting endlessly for serial data that never comes. Which data is send to the serial input? Char array receive is too small and can overflow, by the way.
  5. #5
    Member level 5
    Join Date
    Jun 2015
    Posts
    83
    Points
    670
    Level
    I wanted to send string code such as binary code to pic and pic will execute if it receive 1 in each block array. I am doing this in purpose to hake CNC 2 axis the binary 1 is the coordinate write.
    Please give me more advise!
  6. #6
    Member level 5
    Points: 643, Level: 5
    Join Date
    Jun 2015
    Bangalore
    Posts
    86
    Points
    643
    Level
    Where is your configuration bits initialisation. Can you share that.
    Amit
  7. #7
    Member level 5
    Join Date
    Jun 2015
    Posts
    83
    Points
    670
    Level
    what is the configuration bit ? what do you mean? mikroc or VB?
    •   Alt28th March 2016, 07:12
      advertising
  8. #8
    Member level 5
    Join Date
    Jun 2015
    Bangalore
    Posts
    86
    Points
    643
    Level
    If you are using MPLAB, you will see in the bottom of the window.
    Click image for larger version.
    Check whether WDT is enabled?
    Amit
  9. #9
    Points: 8,290, Level: 21
    Easyrider83's Avatar
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,489
    Points
    8,290
    Level
    21
    It is enabled. Anyway, this code is a bad example of working with UART. Don't share it ))))
    Love me or hate me. All infractions will be ignored.
    •   Alt28th March 2016, 07:30
      advertising
  10. #10
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,962
    Points
    241,624
    Level
    100
    Can you give an example of input data?
  11. #11
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,489
    Points
    8,290
    Level
    21
  12. #12
    Full Member level 2
    Points: 1,266, Level: 8
    Join Date
    Nov 2012
    India
    Posts
    131
    Points
    1,266
    Level
    8
    Or one can also use circular buffer using USART interrupt, it is much more easy than polling for UART_data ready.
    Quote Originally Posted by Johnny Churne View Post
    Hi johnny,
    Try using this code:
    unsigned short q=0;
    void interrupt()
    if(PIR1.RCIF==1)
    receive[q]=UART1_Read();//copy byte by byte in receive
    q++;
    char  receive[64] ;
    void main(){
    int x;
    int i=0;
    TRISA=0X00;
    TRISB=0XFF;
    TRISC=0X80;
    PORTC=0X00;
    PORTA=0X00;
    PORTB=0X00;
    UART1_INIT(9600);
    RCIE_bit=1;
    INTCON.GIE=1;
    PIE1_bit=1;
    delay_ms(100);
    while(1){
    if(q>64)q=0;
    if(receive[0]=='0')
    x=0;
    q=0;//resetting q to 0
    if(receive[1]=='1')
    x=1;
    q=0;
     PORTA=x;
     delay_ms(50);
     PORTA=0X00;
     delay_ms(50);
       uart1_write('F');
    } // end if
    }  // end while
  13. #13
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,962
    Points
    241,624
    Level
    100
    I agree with your suggestion to use UART interrupts. But I actually wanted to ask the OP for an example of the CNC input data.
  14. #14
    Member level 5
    Join Date
    Jun 2015
    Posts
    83
    Points
    670
    Level
    I used MikroC
    it can not compile in PIE1_bit=1;
    what's the problem?
    Mrunal Ahirrao
  15. #15
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,489
    Points
    8,290
    Level
    21
    Use INTCON & PIE
    Never use '==1' with bit values!
  16. #16
    Join Date
    Aug 2015
    Posts
    773
    Points
    3,996
    Level
    14
    Zip and post the complete mikroC project file. I have to see the project settings.
    •   Alt28th March 2016, 11:17
      advertising
  17. #17
    Member level 5
    Join Date
    Jun 2015
    Posts
    83
    Points
    670
    Level
    Quote Originally Posted by pic.programmer View Post
    here is my Zip please check!
  18. #18
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,962
    Points
    241,624
    Level
    100
    The configuration shows WDT disabled. So everything is inside the shown code.
       Address      Value     Field                                 Category        Setting
         2007        2F4A   FOSC      Oscillator Selection bits                                            HS oscillator
                            WDTE      Watchdog Timer Enable bit                                            WDT disabled
                            PWRTE     Power-up Timer Enable bit                                            PWRT disabled
                            BOREN     Brown-out Reset Enable bit                                           BOR enabled
                            LVP       Low-Voltage (Single-Supply) In-Circuit Serial Programming Enable bit RB3 is digital I/O, HV on MCLR must be used for programming
                            CPD       Data EEPROM Memory Code Protection bit                               Data EEPROM code protection off
                            WRT       Flash Program Memory Write Enable bits                               Write protection off; all program memory may be written to by EECON control
                            CP        Flash Program Memory Code Protection bit                             Code protection off
  19. #19
    Full Member level 2
    Join Date
    Nov 2012
    India
    Posts
    131
    Points
    1,266
    Level
    8
    I used MikroC
    what's the problem?
    Mrunal Ahirrao
    hi johnny,
    Oh, I am sorry it was a typo.try using as easyrider83 suggested, or edit that line with PEIE_bit=1; now it should compile and work. I also use MikroC.
  20. #20
    Member level 5
    Join Date
    Jun 2015
    Posts
    83
    Points
    670
    Level
    what is easyrider83 ?
    Quote Originally Posted by FvM View Post
    I really don't understand, my setting is the same as shown but it still doesn't work.
