adwnis123
Full Member level 4
Hello, I want to make a webpage that will display some data and that will run on raspberry. I should use a wifi module attached on one of raspberry's usb. The user should log in with password on the webpage wirelessly and see the data. I will also use tempareture sensor that raspberry should read the data. Can this be done? What OS to install on raspberry that will help me? I think of installing raspbian and write code in python. Or it is better to install Windows and write the code on C#?
