+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 5
    Points: 1,017, Level: 7
    Join Date
    Jun 2014
    Posts
    88
    Points
    1,017
    Level
    7
    login to a webpage running in raspberry through wifi
    Hello, I want to make a webpage that will display some data and that will run on raspberry. I should use a wifi module attached on one of raspberry's usb. The user should log in with password on the webpage wirelessly and see the data. I will also use tempareture sensor that raspberry should read the data. Can this be done? What OS to install on raspberry that will help me? I think of installing raspbian and write code in python. Or it is better to install Windows and write the code on C#?
    •   Alt26th March 2016, 15:20
      advertising
  2. #2
    Member level 5
    Join Date
    Jun 2014
    Posts
    88
    Points
    1,017
    Level
    7
    Re: login to a webpage running in raspberry through wifi
    I would appreciate If you could tell me from where to start!
    •   Alt26th March 2016, 17:43
      advertising
  3. #3
    Advanced Member level 2
    Points: 6,608, Level: 19
    Kurenai_ryu's Avatar
    Join Date
    Jun 2006
    Bolivia
    Posts
    671
    Points
    6,608
    Level
    19
    hey, how are you going with your project? did you already decided how to do it?
    if not, I suggest you to use raspbian and python, you can make a small web server with python FLASK and combine with GPIO or python SERIAL to read your sensor in the same program (to avoid threading if you're a beginner)
    another alternative is use node.js and express to make your web server (but how are you going to read the sensor?) I think I have seen wiringpi examples in node. if you don't know node.js maybe you can check node-red which is a graphical interface (and I think last versions of raspbian comes with node-red pre-installed)
    K~ Ryu
    ~"Sorry my bad english, my native language is C "
