+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 28
  1. #1
    Points: 6,654, Level: 19
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Question about SPI1_Write ?
    Guys,
    Why can't send the complete file to SPI1_write()?
    I'm using MikroC Pro For ARM...
    When I pass the variable to UART1_Write()....I can read all the file content but when I put on SPI1_Write() only top part of the file..
    Anyone knows ?
    Thanks
  2. #2
    Super Moderator
    Points: 25,606, Level: 38
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,699
    Points
    25,606
    Level
    38
    Blog Entries
    Re: Question about SPI1_Write ?
    Certainly you are not referring to UART1_Write() but rather to UART1_Write_Text(), which accept arguments as pointer of an array. Anyway, why should both functions work likewise ? Apropos, you can make your own function SPI1_write_Text() building with the SPI1_write() inside, although a priori would not make much sense, once AFAIK most SPI packs sent by Master device are shorts.
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
  3. #3
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Quote Originally Posted by andre_teprom View Post
    I don't understand what you mean ....
    Why can't I transfer data on SPI1_Write().....but it's transfered ok on UART ??
  4. #4
    Super Moderator
    Join Date
    Nov 2006
    Brazil
    Posts
    7,699
    Points
    25,606
    Level
    38
    Blog Entries
    Quote Originally Posted by bianchi77 View Post
    I'm giving you an example of what I meant at the code posted on the following thread, on which you can see that the function UART1_Write() was used to send a single character, whereas the function UART1_Write_Text() was used to send a string:
  5. #5
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    How can I say it to explain it........when I use UART1_Write
    Please have a look at the code....
    void MP3_SDI_Write(char data_) {
        MP3_CS = 1;
        //while (DREQ == 0);             // wait until DREQ becomes 1, see MP3 codec datasheet, Serial Protocol for SCI
          BSYNC = 0;
        UART1_Write(data_);
        //SPI1_Write(data_);
        BSYNC = 1;
    I send the same data_......
    but when I used SPI1_Write(), it's sending only 512bytes....
    When I used UART1_Write()...it can send the whole files perfectly....
    Why ??
    void Read_Play_MP3()
        unsigned long i, fsize;
        unsigned int j, cnt,count;
        short fhandle;
        char readBuffer[BUFSIZE];
        char str[55];
                 LED = 0;
        fhandle = FAT32_Open("hello.mp3", FILE_READ);
        if (fhandle >= 0)
              UART1_Write_Text("File test1.mp3 opened sucessfully!\n");
              FAT32_Size("hello.mp3", &fsize);
              LongToStr(fsize, str);
              UART_Write_Text("hello.mp3 size: ");
              UART_Write_Text(str);
              UART_Write(CR);
              while (FAT32_Eof(fhandle) != 1)
                FAT32_Read(fhandle, readBuffer, BUFSIZE);
                         count =0;
                            while(count<512)
                               for(j=0;j<32;j++)
                                     if (DREQ == 1)
                                       MP3_SDI_Write(readBuffer[count]); //????
                                       //UART_Write(readBuffer[count]); //????
                                       count++;
                                //Delay_ms(10);
                     LED = 1;
                     Delay_ms(100);
                     LED = 0;
                     UART1_Write_Text("\nDone  !\n DONE! \n");
                     LED = 1;
                     Delay_ms(1000);
                     LED = 0;
                     FAT32_Close(fhandle);
         else
                UART1_Write_Text("Opening file hello.mp3 failure!\n");
    Thanks
    When I used UART1_Write()....the file is completely read :
    hello.mp3 size:
    Done !
    DONE!
    with SPI1_Write()...
    only 512 bytes...not complete file...
    •   Alt18th March 2016, 23:52
      advertising
  6. #6
    Super Moderator
    Join Date
    Nov 2006
    Brazil
    Posts
    7,699
    Points
    25,606
    Level
    38
    Blog Entries
    Sending bytes to what ?
    If worked for 512 bytes, you are missing to analyse the part of the code that calls the function MP3_SDI_Write().
  7. #7
    Super Moderator
    Points: 239,611, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    How exactly? Signalling eof after 512 bytes? or?
    •   Alt19th March 2016, 00:30
      advertising
  8. #8
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Sending the bytes to VS1053....and for a test I used UART
    Quote Originally Posted by FvM View Post
    Eof after file finish...sending 512 bytes on buffer until eof and divide 512 bytes into 32 bytes each...
  9. #9
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    Not answering the question.
    You see eof after 512 bytes although the file is larger than 512 bytes?
    •   Alt19th March 2016, 01:03
      advertising
  10. #10
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Scratch my head....I don't understand....hehehehe
    If I used UART, it can see EOF but if I used SPI it can not see EOF only the first 512 bytes and repeat...never been into EOF....
  11. #11
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    Why don't you report your observation clearly from the start?
    Most likely, from the second function call, FAT32_Read() simply does nothing, the initially read sector data is preserved. You're ignoring the result of FAT32_Read() and don't become aware of it's failure.
    Question is of course why file read is failing, a specific reason can't be seen in the code. I guess there might be an unexpected side effect of SPI1_write() on the SD card SPI interface. Either a problem in your code or a bug of the MikroC built-in libraries.
  12. #12
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    If I increase BUFFSIZE = 2048, I can run send all the file content to SPI1....?
    But what happened if I have 5Mbytes file ???
  13. #13
    Super Moderator
    Join Date
    Nov 2006
    Brazil
    Posts
    7,699
    Points
    25,606
    Level
    38
    Blog Entries
    You had not mentioned anywhere in what context parameter BUFFSIZE is being used, neither answered whether you checked or not the loop where function MP3_SDI_Write() is called, as mentioned in post #6. You're not analyzing the situation in a systematic way.
  14. #14
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,515
    Points
    239,611
    Level
    100
    Increasing BUFFSIZE means you are reading a larger part of the file at once. But you want to read it incrementally.
    As andre_teprom said, you need to analyze why FAT32_Read() is apparently failing on second and succeeding call. Presently you don't even check for successful execution.
    Regarding possible faults, what does
    MP3_CS = 1;
    Why is it only set and not reset? I presume BSYNC is the actual SPI nCS line?
  15. #15
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Ok I will check if it's reading correctly..thanks
  16. #16
    Advanced Member level 3
    Points: 3,996, Level: 14
    Join Date
    Aug 2015
    Posts
    773
    Points
    3,996
    Level
    14
    Zip and post the complete project. Remove all unnecessary codes.
  17. #17
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Quote Originally Posted by pic.programmer View Post
    What MCU and board do you use ?
  18. #18
    Join Date
    Aug 2015
    Posts
    773
    Points
    3,996
    Level
    14
    I use EasyMx Pro for STM32 from mikroE.
  19. #19
    Achievements:
    7 years registered
    Join Date
    Jun 2009
    California
    Posts
    1,296
    Points
    6,654
    Level
    19
    Ok, you can give a try, I used SPI1 on this code
    focus on this function :
    I've tested reading only and VS1053 only...
    See at main()...
    The loop for reading file is working on atmega128
    Please let me know, how's the result ? thanks
    •   Alt23rd March 2016, 13:04
      advertising
  20. #20
    Join Date
    Aug 2015
    Posts
    773
    Points
    3,996
    Level
    14
    Should I just Compile and burn and test ? Any changes to be made ?
    I Compiled, burned and tested. I don't hear anything. It is only Silence.
