+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 3
    Points: 1,012, Level: 7
    Join Date
    Jun 2011
    Posts
    26
    Points
    1,012
    Level
    7
    Flybuck Design Secondary Voltage not correct
    I'm trying to design an isolated flybuck similar to the example design shown in AN-2292 by TI. My simulation is not turning out with the secondary voltage correctly though.
    My design criteria:
    Need isolated 40W (currently set to 11.5V, 3.5A). Ideally I need a controllable signal also, but starting with the basics...
    My LTSpice circuit looks like this:
    Click image for larger version.
    I am subbing in a similar schottkey for the one listed. I want to use a Coilcraft coupled inductor with low DCR. Set to operate at 900kHz currently.
    A few questions:
    I am not getting 11.5V or my 3.5A on the secondary output and am not sure why. Not sure if it has to do with the current ratio or not. Any suggestions would be appreciated there.
    I (in theory) am going to lose something like 1.4W over the diode. Is there any way around this or am I just stuck with that?
    Thanks in advance.
    •   Alt17th March 2016, 19:37
      advertising
  2. #2
    Advanced Member level 5
    Points: 28,436, Level: 41
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    5,959
    Points
    28,436
    Level
    41
    Re: Flybuck Design Secondary Voltage not correct
    coilcraft coupled inductors are 1:1....and by the looks of your buck circuit, you are not going to get enough current flowing in the primary to enable the current that you want for your secondary with a 1:1 coupled inductor.
    •   Alt17th March 2016, 19:55
      advertising
  3. #3
    Join Date
    Jun 2011
    Posts
    26
    Points
    1,012
    Level
    7
    Quote Originally Posted by treez View Post
    Is there any way to get that kind of power out of the secondary? The LT3690 I like because I can place an input at the SS pin and have control over the output. Are there any other methods or architectures that will accomplish the same thing? The only other thought was to have a 28V isolated and then feed it into a normal synchronous buck. This is pretty efficient-but uses a huge amount of board space for the DC-DC converter and the buck with all its large capacitors and inductor.
    •   Alt17th March 2016, 22:35
      advertising
  4. #4
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    5,959
    Points
    28,436
    Level
    41
    Yes just use a flyback or two transistor forward to get the isolated 11.5V, 3.5A.
    Stick with a separate buck for your other output whatever that is?
    Alternatively use a single flyback with two isolated outputs to give you each output.
    I wasn't sure what your actual vin was?
