+ Post New Thread
Results 1 to 19 of 19
  1. #1
    Full Member level 2
    Points: 2,048, Level: 10
    Achievements:
    7 years registered
    ismu's Avatar
    Join Date
    May 2009
    nil
    Posts
    141
    Points
    2,048
    Level
    10
    Doubt on stepper motor ratings
    hi am using SY57STH76-2804A stepper motor , which datasheet rating is
    3.2v , 2.8A and Coil resistance 1.13Ohms .
    1-so can drive thios motor with 12v/24V ?
    2-When i drive with 12V then current will be =12/1.13=10.6A
    3- what is the impact of coil inductance? what should i take care on designing?
  2. #2
    Advanced Member level 5
    Points: 13,005, Level: 27
    Join Date
    May 2015
    Melbourne, Australia
    Posts
    2,213
    Points
    13,005
    Level
    27
    Re: Doubt on stepper motor ratings
    The usual way to do this is to drive it with 12v/24v but with a current limited supply set to 2.8A (or less).
    The higher supply voltage will produce a very fast ramp up of current in the inductive motor windings, right up to the current limit value.
    This makes much faster stepping rates possible, and with higher torque when running fast.
    If you do not need the speed just run the motor at 3.0 volts.
    Cheers, Tony.
    1 members found this post helpful.
    •   Alt10th March 2016, 23:24
      advertising
  3. #3
    Full Member level 2
    Achievements:
    7 years registered
    ismu's Avatar
    Join Date
    May 2009
    nil
    Posts
    141
    Points
    2,048
    Level
    10
    what is the meaning of rated voltage 3.2v ? then how can give >3.2v?
  4. #4
    Join Date
    May 2015
    Posts
    2,213
    Points
    13,005
    Level
    27
    Those are the CONTINUOUS ratings for drive with direct switched dc current.
    You can run it like that but it will be slow, and torque will fall off with increasing speed.
    Cheers, Tony.
  5. #5
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    The usual way to operate a stepper motor at higher voltage is to apply PWM with current regulation.
  6. #6
    Full Member level 2
    Achievements:
    7 years registered
    ismu's Avatar
    Join Date
    May 2009
    nil
    Posts
    141
    Points
    2,048
    Level
    10
    if i use 12v supply instead of rated 3.2v [datasheet rating is 3.2v , 2.8A and Coil resistance 1.13Ohms .]
    then how much should be the Driver chip H bridge driver current capability ?
    i have seen in some case rated volt is less still people are driving with high voltage, any reason?
  7. #7
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    The motor driver should implement constant current operation, maximum current is rated 2.8 A.
    •   Alt22nd March 2016, 18:50
      advertising
  8. #8
    Points: 8,160, Level: 21
    Easyrider83's Avatar
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,464
    Points
    8,160
    Level
    21
    Just use fixed PWM duty cycle to get proper current.
    Love me or hate me. All infractions will be ignored.
    •   Alt22nd March 2016, 21:59
      advertising
  9. #9
    Join Date
    May 2015
    Posts
    2,213
    Points
    13,005
    Level
    27
    A more simple and very crude way to do this is to fit external resistors to each winding.
    If its driven with 12v and you want 2.8 amps, then total resistance needs to be 4.285 ohms.
    The stepper already has 1.13 ohms, so add a 3.15 ohm resistor.
    3R3 would be about right.
    That's a huge 26 watts of power dissipation which really makes it impractical, but it is one possible solution.
    Cheers, Tony.
  10. #10
    Full Member level 2
    Achievements:
    7 years registered
    ismu's Avatar
    Join Date
    May 2009
    nil
    Posts
    141
    Points
    2,048
    Level
    10
    Quote Originally Posted by FvM View Post
    you know any example circuit to get constant current to motor? and should be cheapest way
    Quote Originally Posted by Easyrider83 View Post
    for driving bipolar stepper mototr ,we wrer using pulsed signed on A, A+ ,B, B+ terminal , then how can i make again PWM on this ? can you please draw a simple wave form for half drive signal with PWM ?
    Quote Originally Posted by Warpspeed View Post
    agree.... ! But am driving with 12v Source and motor rating is 3.2v ,,, will it damage?
  11. #11
    Join Date
    May 2015
    Posts
    2,213
    Points
    13,005
    Level
    27
    Not if you use a 3R3 resistor.
    But the resistor is going to get mighty hot.
    Cheers, Tony.
  12. #12
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,464
    Points
    8,160
    Level
    21
    That's not funny, man! You will reduce efficency 5 times. 2.8A * 20V will give 56W power lost on each!
    Quote Originally Posted by ismu View Post
    Just take a PWM frequency 10 times higher than expected step time. For example, if you planing to use 1ms step time, 1kHz per step, use 10kHz or higher PWM frequency. I suppose, 1/10 duty cycle will be good enought. But this is actual only for 'on hold' static mode. For movement PWM duty cycle have to be calculated according constand current law. But if you not planing to use variable frequency, just find a good value for duty cycle that gives you expected force and current. It can be lower than maximum rating shown on sticker.
  13. #13
    Super Moderator
    Points: 55,084, Level: 57
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,144
    Points
    55,084
    Level
    57
    External resistors make no sense because of their huge power loss = heating. But for sure it prevents the stepper from overload.
    A fixed pwm does not give the same benefit as a constant current source regarding stepper speed. But for sure it is a way to drice the stepper with 12V.
    There are a lot of stepper driver ICs with pwm controlled current source. All of them have different price .. and availability.
    You say "the cheapest way".
    With the resistor solution..the huge resistors may not be cheap. You need a power supply able to give the motor power and the resistor power, maybe heatsink, baybe fans. Is it cheap?
    The constant pwm solution...has good efficiency, so you need a smaller power supply, smaller heatsink, maybe no fan. Maybe this is the cheapest way.
    The constant current pwm IC solution is the most flexible. Good efficiency, high motor speed. Power supply is somewhere inbetween the above solutions, depending on motor speed. Small heatsink, maybe no fan.
    So it's on the OP to select the "best solution for him". I recommend to go to a distributor site for stepper motor driver ICs and find "cheap" IC with all the specifications, read through datasheets and compare them...
    (Try farnell, digikey, mouser ...)
    Hope this helps, although you need to spend some time.
    Good luck
    Klaus
    Added to easyrider's post:
    Just to safe the motor from overcurrent the max duty cycle is: (raw estimation)
    Motor_voltage / Supply_voltage = 3.2V /12V = 0.266 = 27%.
    For a true constant current it will move from 100% down to about 27% after each step.
    Klaus
  14. #14
    Join Date
    May 2015
    Posts
    2,213
    Points
    13,005
    Level
    27
    I agree fixed resistors are an ugly solution.
    But some low impedance automotive fuel injectors still use series ballast resistors to achieve pretty much the same thing.
    Cheers, Tony.
  15. #15
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,464
    Points
    8,160
    Level
    21
    Quote Originally Posted by KlausST View Post
    My calculations for 24V
  16. #16
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    Constant pwm works like lower constant voltage and doesn't bring the advantage of constant current: faster phase current rise and thus higher speed. At best you get faster current decay in free wheeling which is restricted in a low voltage bridge driver.
  17. #17
    Join Date
    Oct 2011
    Tallinn, Estonia
    Posts
    1,464
    Points
    8,160
    Level
    21
    Sure, for real device purpose there are a lot of difficult calculations have to be performed for proper accelaration and perfomance.
  18. #18
    Full Member level 2
    Achievements:
    7 years registered
    ismu's Avatar
    Join Date
    May 2009
    nil
    Posts
    141
    Points
    2,048
    Level
    10
    thanks ,, understood
    •   Alt24th March 2016, 04:46
      advertising
  19. #19
    Join Date
    May 2015
    Posts
    2,213
    Points
    13,005
    Level
    27
    Jut try running the stepper motor at reduced current and see how it performs.
    It may have sufficient speed and power for your purpose at only half an amp.
    You will never know unless you try it.
    In that case, some 22 ohm resistors running off 12v might be all you need.
    Power would be about six watts which should be tolerable.
    Cheers, Tony.
