+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 2
    Points: 567, Level: 5
    Join Date
    Mar 2016
    Posts
    45
    Points
    567
    Level
    Differential Microstrip Antenna Simulation in HFSS (Incorrect Results)
    I have designed a dual layer differential microstrip antenna .This is my first HFSS simulation model and also I am very new to Antenna theory. This was designed based on a research paper . The model is running but the results aren't as they should be. (Like VSWR is highest at working frequency of 900 MHz; real and imaginary part of Z0 are coming zero for all frequencies.
    Can someone kindly check this and say where is the error in this design. ? I have attached the HFSS file and the VSWR plot
    •   Alt9th March 2016, 17:44
      advertising
  2. #2
    Member level 1
    Points: 550, Level: 4
    Join Date
    Jan 2016
    Edinburgh, Scotland
    Posts
    35
    Points
    550
    Level
    Re: Differential Microstrip Antenna Simulation in HFSS (Incorrect Results)
    Hi
    You should put the Radiation Boundary at least lambda/4 away from the radiating parts of the structure. Calculate the distance and draw a bigger radiation box.
    •   Alt10th March 2016, 07:13
      advertising
  3. #3
    Member level 2
    Join Date
    Mar 2016
    Posts
    45
    Points
    567
    Level
    Hi rizoeda,
    Thank you for your response. Yes I implemented it and also my model was incorrect and made some changes. I am getting realistic results now.
    But the main problem was that I was getting linear graphs of this kind. It happened because I added only a few steps in my frequency sweep. Its solved as of now.
    Best Regards
