+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 2
    Points: 23, Level: 1
    Join Date
    Mar 2016
    Posts
    Points
    23
    Level
    APC UPS ES 500 back up battery doesnt work
    When I plug my ups apc es500 on the outlet it works perfectly fine but when a power outage occurs or if I unplug my UPS in the outlet my computer will turn off and a continous beeping sound occurs without the green light. I tested the battery using multimeter and it works perfectly fine the indicator shows 12volts to 13 volts.. Please help me with this problem. Thanks in advance
    •   Alt9th March 2016, 15:14
      advertising
  2. #2
    Super Moderator
    Points: 46,787, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,662
    Points
    46,787
    Level
    52
    Re: APC UPS ES 500 back up battery doesnt work
    The batteries can read okay on a voltmeter but then lack the power to drive a load. They develop internal resistance, and this reduces how much Amperes they can put out.
    From my experience with a backup UPS, the batteries only last a few years (whether they are used much or little.) Then they must be replaced. Often they are gel cells. These are not made to have the lifetime of a deep cycle lead-acid battery.
    1 members found this post helpful.
    •   Alt9th March 2016, 20:42
      advertising
  3. #3
    Newbie level 2
    Join Date
    Mar 2016
    Posts
    Points
    23
    Level
    Thank you for your quick response, so are you suggesting me to buy a new battery replacement in my UPS?? Does this solve my issue regarding my UPS? Thank you
    •   Alt10th March 2016, 09:42
      advertising
  4. #4
    Advanced Member level 5
    Points: 13,321, Level: 27
    Join Date
    Nov 2012
    Posts
    2,482
    Points
    13,321
    Level
    27
    Quote Originally Posted by BradtheRad View Post
    I call this a design feature. I believe all maintenance free lead acid batteries are gel cells. The capacity also decreases steadily (almost from the beginning) and they rarely last more than 2 years. The ones with external batteries last far longer (one is still alive and kicking after 4 years). I originally suspected that there are some faults in charging program but now I believe that I am wrong, as usual.
