+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 1
    Points: 1,570, Level: 9
    Achievements:
    7 years registered
    diamadiss's Avatar
    Join Date
    Mar 2010
    Posts
    34
    Points
    1,570
    Level
    9
    Connect two USB hosts parallel with a slave
    I want to design a pcb which will connect with a tablet (slave) either an Arduino PCB (host) and either with a PC (host). At the below image i took a senario where of a trouble shouting all devices will connect together (for instance because all relays are damge). My question is if and the three VDD of three devices (below picture) will connect parallel (two USB host devices parallel connected with a slave device-tablet) this will cause a damage to the devices or just there will not be a valid connection between them?
    •   Alt28th February 2016, 22:32
      advertising
  2. #2
    Super Moderator
    Points: 46,805, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,670
    Points
    46,805
    Level
    52
    Re: Connect two USB hosts parallel with a slave
    Do you plan for external power adapters going to your devices? This is safe only if you can verify that the power supplies have internal isolation from mains. If not, then there could be unknown connections to mains AC, which could result in abnormal current flow between the devices, possibly causing a short circuit.
    •   Alt29th February 2016, 02:17
      advertising
  3. #3
    Member level 1
    Achievements:
    7 years registered
    diamadiss's Avatar
    Join Date
    Mar 2010
    Posts
    34
    Points
    1,570
    Level
    9
    The one supply is from computer (usb output) and the other is from arduino where arduino is powered from a switching supply 230/12Volt with an internal transformer (magnetic isolation). With these power specifications I will have a short circuit between all powers?
    •   Alt29th February 2016, 05:46
      advertising
  4. #4
    Super Moderator
    Join Date
    Apr 2011
    Posts
    11,670
    Points
    46,805
    Level
    52
    Since you have isolation, then it should be okay to connect those devices. Come to think of it, I have USB drives which run from a power adapter, and I plug them into my computers without thinking about whether it has isolation.
