HI-TECH Pic.C example code for pic MCUs ?
agnivesh
Member level 2
UK
I'v just started learning programming PIC mcu's using hi-tech's picc compiler. I need some example source codes from some projects to see how c language is used to program PIC mcu.
Can somebody please suggest me online resources for some sample source codes using hi-tech's picc for PIC mcu's ?
by the way, do you have any better suggestion for me for learning that more easily and quickly ?
thanks in advance
agnivesh
Re: HI-TECH PIC-C EXAMPLE CODES FOR PIC MCUs ?
try to look at
www.microchipc.com
you can also check in the sample folder of hitech picc there are many sample program
    agnivesh
Under the PICC compiler directory you will find an example folder. There you will find lots of examples in C on how to connect or use the PIC MCU.
Also, you will find a pdf under the manual directory with a full explanation.
In the web site that was posted before, have a look at the FAQ, there you will find also alot of examples on how to connect and what featres you can use.
And the last thing to do is to search this forum, there are many examples and links for learning the PIC MCU.
If you found my answer useful, click on the button that says Helped me. ( NO points will be taken from you! )
Good luck.
    agnivesh
Where is the button?
faq at microchipc.com is nice, it helps.
Is there any particular ebook available to learn pic programming using hi-tech's picc ?
if somebody has that, then please upload it ?
thanx to all of u for the help
agnivesh
