[SOLVED] AVR code for M590 neoway (initializing and sending text message)
aminpix
I am trying to work with GSM module M590/Neoway connected to a Atmega32A.
I went through the command set and datasheet. but still I can't communicate with M590. for example i wrote the following code to get any response from M590, but after running the code, i didn't get anything from M590.
Is there anybody here can help me and share some code (especially AVR, because I only know AVR micro-controllers) with me.
#ifndef F_CPU
#define F_CPU 8000000UL // 8 MHz clock speed
#endif
#include <avr/io.h>
#include <util/delay.h>
#include <avr/interrupt.h>
#define USART_BAUDRATE 115200
#define BAUD_PRESCALE (((F_CPU / (USART_BAUDRATE * 16UL))) - 1)
volatile unsigned char value;
volatile unsigned char LED_ind ;
ISR(USART_RXC_vect){
   value = UDR;             //read UART register into value
   LED_ind = 0b00000100 ;
   PORTA = LED_ind ;
   _delay_ms(3000);
void uart_init()
    UCSRB = ((1<<RXEN) | (1<<TXEN) | (1<<RXCIE));   // Enable Receiver, Transmitter, Receive Interrupt
    UCSRC = ((1<<URSEL) | (1<<UCSZ1) | (1<<UCSZ0));     // 8N1 data frame
	UBRRL = BAUD_PRESCALE;// Load lower 8-bits into the low byte of the UBRR register
    UBRRH = (BAUD_PRESCALE >> 8);
void USART_SendByte(uint8_t u8Data)
  // Wait until last byte has been transmitted
  while((UCSRA &(1<<UDRE)) == 0);
  // Transmit data
  UDR = u8Data;
void uart_putc(unsigned char c)
    // wait until UDR ready
    while(!(UCSRA & (1 << UDRE)));
    UDR = c;    // send character
uint8_t USART_ReceiveByte(){
  while((UCSRA &(1<<RXC)) == 0);
  PORTA = LED_ind ;
  _delay_ms(2000);
  return UDR;
void uart_puts(char *s,int s_size)
    //  loop until *s != NULL
	for(int i = 0 ; i < s_size; i++)
        uart_putc(s[i]);
int main(void)
	DDRA = 0xFF;       //Configure PortA as an Output port
	uart_init();
	sei();         // enable all interrupts
	char *str ;
    while(1)
        //TODO:: Please write your application code
		LED_ind = 0b00000000 ;
		PORTA = LED_ind ;
		_delay_ms(500);
		LED_ind = 0b00000001 ;
		PORTA = LED_ind ;
		_delay_ms(500);
		uart_puts("AT+CREG?",8);
		PORTA = LED_ind ;
		USART_ReceiveByte();
		_delay_ms(1000);
You are missing the enter key code \n or 0x13 after sending AT command.
My code looks like below, instead of writing own puts, its better to use built in printf functions.
