+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Member level 4
    Points: 2,293, Level: 11
    Join Date
    Jul 2004
    Posts
    76
    Points
    2,293
    Level
    11
    walkie talkie schematic
    I would like to bulid a two way radio ( walkie - talkie) for my little sister range around 1-5km.. Does anybody have the circuit schematic for it.. thanks..
    •   Alt24th March 2005, 10:41
      advertising
  2. #2
    Full Member level 5
    Points: 3,276, Level: 13
    Join Date
    Jan 2005
    Asia
    Posts
    311
    Points
    3,276
    Level
    13
    walkie talkie circuit diagram
    A 49 Mhz Walkie talkie schematic is available. This and much more can be found out at :
    http://jap.hu/electronic/rf.html
    check it out it works i've tried it !
    bye
    •   Alt24th March 2005, 21:23
      advertising
  3. #3
    Member level 4
    Join Date
    Jul 2004
    Posts
    76
    Points
    2,293
    Level
    11
    walkie talkie schematics
    there are several part that i dony understand. what is number 1,4 and 6.. how many turns for tranformer 3 and 5.. what is the value of inductor 2 (henry).. if i build 2 of these it can automatically works as a walkie talkie?? thanx...
    •   Alt25th March 2005, 19:59
      advertising
  4. #4
    Newbie level 1
    Points: 322, Level: 3
    Join Date
    Mar 2011
    Posts
    Points
    322
    Level
    Re: need circuit schematic for 2 way radio ( walkie talkie)
    hay everyone can help i need it plz help
    everyone have this schematic insert here
  5. #5
    Newbie level 3
    Points: 284, Level: 3
    Join Date
    Feb 2012
    Posts
    Points
    284
    Level
    how to increase the 49 mhz walkie-talkies receiver sensitivity?
    how to add no of transistor in the audio section how?
    •   Alt15th March 2012, 11:03
      advertising
  6. #6
    Advanced Member level 3
    Points: 5,945, Level: 18
    Achievements:
    7 years registered
    Join Date
    Jul 2009
    Sydney, Australia
    Posts
    834
    Points
    5,945
    Level
    18
    Re: walkie talkie schematics
    Quote Originally Posted by huji View Post
    1,4,6 are 3 sets of contacts on a switch that you operate to switch between transmit and receive
    Inductors 3 and 5 are a bit trickier as these will be factory produced and probably within metal cans
    Inductor 2 is primarily some base loading of the telescopic whip to get it a bit closer to resonance probably ~ 10 turns airspaced no former would get you into the right area
    you can see that the inductor you have labelled as 3 is slug tune. its the tank circuit of the 49MHz oscillator and also matching to the antenna
    inductors 3 and 5 are likely to be the stumbling blocks. Maybe others mite have some other suggestions
    Dave
