+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Full Member level 4
    Points: 1,925, Level: 10
    Join Date
    Feb 2012
    Posts
    221
    Points
    1,925
    Level
    10
    black screen when laptop boot
    hi.
    I have a sony vaio laptop that does not boot.
    my model: VGN-CS 190
    i was using from visual studio 2010 and next installed an antivirus.
    this antivirus found a trojan and I cleaned it.next my laptop was busy and I restarted it.but the laptop went to black screen (after vaio logo) and did not boot.
    my solution:
    I used from a bootable CD windows and flash,but they did not load at all!
    when I used from them in my computer,both of CD and flash worked truly.
    I pressed F2 and changed boot order,but does not read CD or flash yet.
    I pressed F8 and in "advanced boot screen",used from all options,but does not load my windows or load CD or flash,yet.
    I removed memory cards and replaced them again.I replace the battery.but did not change anything.
    in vaio recovery center (by F10) : I saw my hardware does not any problem.
    is there anyone who help me?
    •   Alt31st January 2016, 18:52
      advertising
  2. #2
    Super Moderator
    Points: 46,787, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,662
    Points
    46,787
    Level
    52
    Re: black screen when laptop boot
    You mention trying to operate several devices. It unclear which combination works or doesn't work.
    When I have a computer that does not start up, I try to track down the problem by removing all unneeded devices. Things that I can remove are the hard drive, ram, external devices. The aim is to discover which central parts of the computer still operate. I have emergency boot CD's which contain utilities.
    I change one thing at a time. If something works then I add something else, or switch things around, until I find a component that doesn't work. It might require several shutdowns and startups.
    If the hard drive cannot be read, then I start up from a different disk, or different OS, etc. Often I allow only one disk to be the startup disk. If I allow it to choose between two disks, I can't always know why it rejects one and chooses the other, or whether the other was the default, or which.
  3. #3
    Newbie level 3
    Points: 33, Level: 1
    Join Date
    Apr 2016
    Posts
    Points
    33
    Level
    Try using Safe mode with networking. And try to restore the system to an earlier date. Or check your Master Boot Record (MBR).
    •   Alt17th April 2016, 10:53
      advertising
  4. #4
    Advanced Member level 2
    Points: 3,764, Level: 14
    Join Date
    Apr 2010
    UK
    Posts
    547
    Points
    3,764
    Level
    14
    Not booting from CD or flash tends to suggest something fundamental not OS related.
    Things to try:
    Listen for any beeps as the machine starts up. Count them.
    Check your bios settings.
    If your machine can output to a different display - plug a cable in and see if you can get any output there
    In situations like this I have a boot flash drive with diagnostics on it - but if even flash still doesnt work that won't help
    and you may be better off asking the manufacturer if the above fails. Do a google search for your machine with the name
    of the antivirus you used - that may tell you something.
  5. #5
    Member level 1
    Points: 696, Level: 5
    Join Date
    Apr 2014
    Posts
    34
    Points
    696
    Level
    I ran into the same problem with my ACER laptop in January and this fixed it but it wasn't a permanent fix, though. After that incident my lappy wasn't able to detect his battery and keys were always stuck. Needed to buy a new lappy by the end of April.
    •   Alt28th July 2016, 23:20
      advertising
  6. #6
    Newbie level 3
    Points: 19, Level: 1
    Join Date
    Aug 2016
    Posts
    Points
    19
    Level
    This happened to my laptop just this morning. I'm not really a techie one but I will try to follow the things you first did. I hope it works. :)
  7. #7
    Newbie level 3
    Join Date
    Aug 2016
    Posts
    Points
    19
    Level
    I guess, there is something wrong with the hardware. its better to consult some service centre
  8. #8
    Member level 1
    Join Date
    Apr 2014
    Posts
    34
    Points
    696
    Level
    Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot.
  9. #9
    Newbie level 2
    Points: 16, Level: 1
    Join Date
    Jan 2017
    Posts
    Points
    16
    Level
    press f2 and in bois tray to chang the hard disk opitinos one after one and see what will happen
    I work in the field of computers and mobile and I am a site manager http://laptop2all.com then i can help you in computers price comparison for free
  10. #10
    Super Moderator
    Points: 69,545, Level: 64
    Achievements:
    7 years registered
    Awards:
    2nd Helpful Member
    betwixt's Avatar
    Join Date
    Jul 2009
    Aberdyfi, West Wales, UK
    Posts
    11,367
    Points
    69,545
    Level
    64
    I would suggest inserting a USB stick or DVD with a bootable version of Linux on it, Ubuntu for example. That will demonstrate whether the problem is hardware or software as none of the original software will be touched, it will boot entirely from the DVD. If it does boot up that way, you can run diagnostics or even repair the Windows installation from it then just remove the DVD and reboot as normal afterwards. A bootable Ubuntu DVD has allowed me to fix many dead or corrupted Windows installations for people and in some cases salvage all the users files when the computer would be otherwise be scrap.
    Brian.
    PLEASE - no friends requests or private emails, I simply don't have time to reply to them all.
    It's better to share your questions and answers on Edaboard so we can all benefit from each others experiences.
    •   Alt29th January 2017, 21:00
      advertising
  11. #11
    Newbie level 1
    Points: 13, Level: 1
    Join Date
    Jul 2017
    VIRGINIA
    Posts
    Points
    13
    Level
    some thing else for, you just remove for battery and charging cable just one or two mints ,then you restart your laptop i think cleared that Errors.,
