asking
Full Member level 5
In the Image... i am trying to put 30A 12V Relay OMRON G8P-1A4P 12VDC parallel to Push Start Button (Dual Starter control for 1HP Pump Motor). But every time relay picks up contact stick... Before using Relay i was using 25A 24-480VAC SSR (Zero Crossing) but 4-5 of them failed due to large Surge / Inrush current. So i switched to Relay. But now relay contacts are sticking.
I also tried to add RC Snubber 0.1uF 600V + 66 Ohms but did'nt help.
Please suggest some idea how i can i avoid Arcing. Relay contact are rated for 30A / 250VAC my load is max 20A for just 0.5-1 Second. Then contactor picks up and motor is operated through Contactor. No load is given to relay later on.
Please suggest...me a Quick way to overcome this problem
