[SOLVED] Error while exporting hardware platform for sw dev tools + Vivado 2015.4
dpaul
Advanced Member level 5
Germany
Would like suggestions on what & where I am going wrong.
Target: Develop a Hello World C code to be run on a MicroBlaze MCS processor implemented on Artix AC701 using Vivado 2014.4 and SDK.
What is done: Upto bit file generation of my top level design file which just contains the instantiation of the uB MCS.
module mb_mcs_top(
    input  clk_top,
    input  reset_top,
    output UART_Tx,
    input  UART_Rx
    wire clk, reset;
    wire uart_tx, uart_rx;
    assign clk = clk_top;
    assign reset = reset_top;
    assign uart_rx = UART_Rx;
    assign UART_Tx = uart_tx;
    microblaze_mcs_0 microblaze_mcs_0_inst (
      .Clk(clk),          // input wire Clk
      .Reset(reset),      // input wire Reset
      .UART_Rx(uart_rx),  // input wire UART_Rx
      .UART_Tx(uart_tx)  // output wire UART_Tx
endmodule
I have performed the 'Generate Block Design' for my top level too.
Now before starting to use SDK, the two most imp. steps involved are
1. Importing the Hardware Platform Specification, and
2. Board support package
Problem:
From Vivado, when I do File > Export > Export Hardware, with the option "Include Bitstream", I get the error message that my "hardware handoff file (.sysdef)" is missing. Please the attached screen shot of my error message.
If I don't attach the bitstream, I still have the same problem.
write_hwdef -force -file D:/work/scratch/mb_mcs_core/mb_mcs_top.hdf
INFO: [Vivado_Tcl 4-424] Cannot write hardware definition file as there are no IPI block design hardware handoff files present
I also tried the TCL commands.
set PROJECT_NAME "my_project"
set TOPLEVEL_NAME "toplevel"
write_hwdef -force -file ./$PROJECT_NAME.runs/synth_1/$TOPLEVEL_NAME.hwdef
write_sysdef -force -hwdef ./$PROJECT_NAME.runs/synth_1/$TOPLEVEL_NAME.hwdef -bitfile ./$PROJECT_NAME.runs/impl_1/$TOPLEVEL_NAME.bit -file ./$PROJECT_NAME.runs/impl_1/$TOPLEVEL_NAME.sysdef
When I run the 'write_hwdef' command I get the error message that -
write_hwdef -force -file ./mb_mcs_core.runs/synth_1/mb_mcs_core.hwdef
I would like to know what has to be done to solve the above problem.
I have also opened a Xilinx community thread on this topic:
http://forums.xilinx.com/t5/Embedde...ackage-SDK-does-not-work-a-failed/td-p/677675
For the benefit of others...
Being new to Vivado, I found out that one needs create the design in the form of a *.bd (Block Diagram). Coming from an ASIC background this was not intuitive to me and I couldn't find it *written straightforward* in any of the Xilinx specs that if the top-level is not a *.bd one would be problems exporting the design for use in SDK.
I really don't like this BD process (and so are many people like me).
http://forums.xilinx.com/t5/Embedde...a-smooth-transition-to-SDK-if-top/td-p/678281
