confused about sample rates
engineer1000
I am now really confused. With reference to the reply below
" on the other hand, you were willing to work with a slighlty reduced bandwidth and sample rate of 125S/s, then you could use a PicoScope 5442A."
The 5442A is spec'ed at up to 1GS/s real time sampling, even using 4 channels would give me 2150KS/s . So I really don't understand where the 125S/s comes from.
THANKS
Usually with digital scopes..when you change the timing (ms/div) you change the sample rate.
So i assume the 5442 is able to sample with max 1Gs/s, but it may be set up for a lower sample rate.
Quoting a single sentence picked up somewhere without a link or explaining the context seems to me like a useless post
If the question is somehow related to your thread https://www.edaboard.com/threads/349076/ you should consider that a related questions should be asked in one thread.
