+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Advanced Member level 3
    Points: 3,827, Level: 14
    Join Date
    Oct 2011
    Posts
    772
    Points
    3,827
    Level
    14
    Multi cycle path of N clock cycles
    How to specify the setup and hold for a multi cycle path of clock cycles N. Can anybody specify the correct syntax completely for both setup and hold?
  2. #2
    Advanced Member level 2
    Points: 3,454, Level: 13
    Join Date
    Apr 2011
    India
    Posts
    552
    Points
    3,454
    Level
    13
    Re: Multi cycle path of N clock cycles
    Check the command guide of the tool you are using....
    •   Alt25th November 2015, 14:03
      advertising
  3. #3
    Join Date
    Oct 2011
    Posts
    772
    Points
    3,827
    Level
    14
    Quote Originally Posted by sharath666 View Post
    I do not have the guide. It is not dependent on tool. Please provide the exact syntax.
  4. #4
    Join Date
    Apr 2011
    India
    Posts
    552
    Points
    3,454
    Level
    13
    I suppose you are using some tool like Dc compiler and you want to specify a multicycle path constraint for a design...right ???
    •   Alt26th November 2015, 08:36
      advertising
  5. #5
    Join Date
    Oct 2011
    Posts
    772
    Points
    3,827
    Level
    14
    Yes Synopsys design compiler. I do not have any access now to any manual. There is no way.
  6. #6
    Join Date
    Apr 2011
    India
    Posts
    552
    Points
    3,454
    Level
    13
    Type "set_multicycle_path --help" at the command prompt. It will display the command syntax for you. If I remember right, there are options like -setup and -hold to specify the setup and hold options..
  7. #7
    Full Member level 3
    Points: 1,039, Level: 7
    Join Date
    Dec 2014
    Posts
    158
    Points
    1,039
    Level
    7
    This link may help you.
    http://vlsi.pro/multi-cycle-paths/
    1 members found this post helpful.
    •   Alt26th November 2015, 09:46
      advertising
  8. #8
    Join Date
    Oct 2011
    Posts
    772
    Points
    3,827
    Level
    14
    The question is where the setup and where the hold check should happen and how the set_multicycle_path will appear with that . Please provide that information.
  9. #9
    Full Member level 4
    Points: 1,498, Level: 8
    Join Date
    Oct 2015
    Posts
    237
    Points
    1,498
    Level
    8
    For me, set_multicycle_path is used with below condition:
    - Timing violation on a path.
    - Functional verification prove that, there is more than 1 cycle for capture FF to use the signal propagated from launch FF, on that path.
    Hence, you need to ask Logic designer to provide set_multicycle_path.
    If you dont have it, just start doing without set_multicycle_path, then collect the violated paths and review them. Pass them to designers for their comment on multicycle possibility.
    Hope this helps.
