SharpWeapon
Member level 5
I am having an issue in combining two clocks signals in one project. I am using DE2 Altera board. I am also using Nios processor. So, basically I am trying to merge to independently working projects into one and build my thing on it. I have one clock signal 50MHz for one project and I have another 27MHz signal for another project. I ported mapped all modules correctly to one project and everything went fine.
But then I am not getting what I wanted when programming my FPGA. I am getting the following warnings:
CLOCK_50 was determined to be clock but was found without an associated clock assignment.
PLL1|altpll_component|PLL|clk[0] was found missing 1 generated clock that corresponds to a base clock with a period of :20.00
PLL2|altpll_component|PLL|clk[0] was found missing 1 generated clock that corresponds to a base clock with a period of :20.00
Someone have an idea on this?
Thanks!
Thanks!
