Yosmany325
Member level 3
Hello everyone, I want to use the XPS I2C IP Module (v2.03a) to interface an external memory chip (24LC512) in an embedded system based on Microblaze Xilinx's processor. My question is about the external connections. From the IP module datasheet I read the signal names and descriptions but I'm not sure if is possible to directly use the signals Sda and Scl shown in the Ports section (see the highlighted names in the figure attached).
I want to know if internally the IP module has the open drain buffers required for I2C bus and I must provide external pull ups or if I must insert the buffers and connect them to the IP module. Thanks in advance. Yosmany325
