beginner_EDA
Full Member level 4
I have problem in understanding VSS-Monitoring ethernet trailer in Wireshark.
I am analysing UDP data sent from FPGA to PC and 2 byte VSS-Monitoring ethernet trailer appears at the end of every UDP packet and It contains last 2 bytes of the packet sent from FPGA.
But When I choose the packet size not multiple of 4 byte, it doesn't appear in Wireshark but then I loose 2 byte data and wireshark also says bad udp length.
I have 32 bit (4 byte) input to FPGA.
How to solve this problem?
