I2C using normal controller IO in Multi Master - is it ok?
chicken_feet
Member level 4
Hi all,
I have just started reading I2C and just wondering if anyone has successfully implemented multimaster I2C using normal controller I/O. Based on what i have read, it seems that it is workable that we implement i2c communication between two controllers without I2C pins. For example we can send a bit and then read back to check for collision. If a collision does happen, we go for arbitration.
I need some confirmation, and if anyone foresee or encountered problem implementing it. Currently i am using 8052 which doesn't requires me to set any Data Direction (I/O) bits and i am wondering will there be problem for other controllers if we change the Data Direction bits ( for specifying Input or Output) in the middle of operation.
rgds,
chicken_feet
Re: I2C using normal controller IO in Multi Master - is it
I2C uses open drain configuration so multimaster environment using 8052 without I2C interface is not good idea.
What you can do is use I2C driver IC such as PCD8584 or similar (see Philips application note AN25)
Added after 5 minutes:
Here is the link to another application note AN425:
Hi
I think you can do that by turn the I/O into input port when ever you finished using the bus
All the best
Bobi
