+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 2
    Points: 420, Level: 4
    Join Date
    Oct 2015
    Posts
    Points
    420
    Level
    HFSS integration line problem
    Hello all,
    i recently started with hfss and needed to add a wave port however while defining the integration line for the wave port to the face parallel to yz plane , the distance along x-axis is showing zero , this causes the wave to oscillate about a point rather than travel along a line
    Thanks Again
    •   Alt20th October 2015, 16:44
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,008, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    944
    Points
    6,008
    Level
    18
    Re: HFSS integration line problem
    Quote Originally Posted by 1sand0s View Post
    this causes the wave to oscillate about a point rather than travel along a line.
    What do you mean "oscillate about a point"? What are the boundary conditions on the four port walls?
    •   Alt21st October 2015, 16:06
      advertising
  3. #3
    Junior Member level 2
    Points: 1,439, Level: 8
    Achievements:
    7 years registered
    Join Date
    Dec 2010
    Posts
    20
    Points
    1,439
    Level
    8
    It seems you want to feed a simple wave-guide. If so, why do you define an integration line? HFSS considers wave-port as an infinite wave-guide which automatically feed correctly, I mean with correct polarization and the dominant mode. In lump port definition you have to define an integration line.
    1 members found this post helpful.
    •   Alt22nd October 2015, 21:22
      advertising
  4. #4
    Junior Member level 1
    Points: 303, Level: 3
    Join Date
    Oct 2015
    's-Hertogenbosch
    Posts
    16
    Points
    303
    Level
    I see in your message log that you performed a geometry modification on your boundary. If this modification touches the integration line it is removed and needs to be reassigned after the modification. I'm not sure if this will solve your problem but at least it will solve the message in the log.
