+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Full Member level 2
    Points: 1,194, Level: 7
    stackprogramer's Avatar
    Join Date
    Jul 2015
    Posts
    149
    Points
    1,194
    Level
    7
    why we don't use AI for PCB Auto Routing in Altium designer???
    hi dear,i know that AI is very important today.
    when i uses Altium designer and select Auto route and rules are strict
    it don't work perfectly and i had to use manual route????
    why AI is not in Altium Designer that can be very powerful in routing!
    it is impossible????
    thanks for reply.
    •   Alt19th October 2015, 11:01
      advertising
  2. #2
    Super Moderator
    Points: 26,005, Level: 39
    andre_teprom's Avatar
    Join Date
    Nov 2006
    Brazil
    Posts
    7,841
    Points
    26,005
    Level
    39
    Blog Entries
    Re: why we don't use AI for PCB Auto Routing in Altium designer???
    On what basis can you state that AI techniques are not actually used at this feature ?
    By the way, AI is a generic term used for a knowledge field, having numerous algorithms that achieve such functionality, and even the most powerful one may have not a better performance when compared with the human mind; the machine is only faster, not smarter. It is precisely in the most critical cases, where human intelligence can finalize a layout, seeing alternative routes, or even deliberately "violating" certain rules or repositioning components during routing time ( something the auto-router would not do).
    In general, for the auto-router works effectively, it must be properly configured in respect to the rule's parameters .
    Part of the world that you live in, You are the part that you're giving ( Renaissance )
    1 members found this post helpful.
    •   Alt19th October 2015, 16:31
      advertising
  3. #3
    Full Member level 2
    Join Date
    Jul 2015
    Posts
    149
    Points
    1,194
    Level
    7
    @andre_teprom thanks,for reply,
    i thought that by the graph theory and the path between dots ,in future we can find a algorithm,of course you are right it is not practical.
