Simplification of Boolean Expression
blade88
Junior Member level 2
Hello,
I am trying to simplify the following expression:
F=A'BC'D+A'BCD'+AB'C'D+AB'CD'+ABCD
However, the Karnaugh Map doesn't show any pairs of ones.
Are there any suggestions?
Thanks
not in terms of not-and-or logic. Maybe there is something using xor.
For FPGA applications, it is a 4LUT -- K-maps don't make sense for FPGA applications. (you should still know them for interviews)
It's been a long time since I posted here.
I solved it:
F=A'BC'D+A'BCD'+AB'C'D+AB'CD'+ABCD=
=(A'B+AB')C'D+(A'B+AB')CD'+ABCD=
=(A'B+AB')(C'D+CD')+ABCD=
=(A XOR B)(C XOR D)+ABCD
Using Karnaugh Map, I should find F' using zeros in the table and I could find the same result.
Thank you
