+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Advanced Member level 5
    Points: 10,533, Level: 24
    Achievements:
    7 years registered
    tony_lth's Avatar
    Join Date
    Jul 2010
    Beijing
    Posts
    1,929
    Points
    10,533
    Level
    24
    pls recommend one ALC IC
    Hi, All,
    I need one ALC IC, pls recommend one latest IC, though I found a lot of old big IC.
    Freq: DC-300Hz
    Supply Voltage: +3.3V/-3.3V
    Output Vpp: 1V
    Dynamic range: >30dB
    It's better a non-class-D amplifier due to noise.
    Thanks.
    It's better that the output signal voltage can be controlled by a analog voltage.
    I hope to find a IC which output signal level can be controlled by a voltage.
    •   Alt2nd October 2015, 22:04
      advertising
  2. #2
    Points: 13,334, Level: 27
    schmitt trigger's Avatar
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,244
    Points
    13,334
    Level
    27
    Re: pls recommend one ALC IC
    Please share the "big old IC" part numbers which you have already found, to avoid making duplicate suggestions.
