+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 1
    Points: 1,488, Level: 8
    Join Date
    Feb 2005
    Posts
    18
    Points
    1,488
    Level
    8
    Directivity and Gain
    I want to know the difference between directivity and Gain, why some books used this termine as the same?
    •   Alt15th March 2005, 23:43
      advertising
  2. #2
    Advanced Member level 5
    Points: 32,456, Level: 44
    Join Date
    Apr 2002
    USA
    Posts
    3,942
    Points
    32,456
    Level
    44
    An antenna's gain increases with its directivity. Think about a transmitting antenna - by increasing its directivity (narrowing its beamwidth), the transmitted power is concentrated into a smaller beam. Inside that beam the signal is stronger, which means more gain.
    •   Alt16th March 2005, 01:11
      advertising
  3. #3
    Full Member level 2
    Points: 3,330, Level: 13
    Join Date
    Feb 2002
    Posts
    121
    Points
    3,330
    Level
    13
    Re: Directivity and Gain
    Simply, gain is directivity minus circuit losses. If losses are negligible, then directivity=gain.
    •   Alt16th March 2005, 14:16
      advertising
  4. #4
    Full Member level 6
    Points: 3,271, Level: 13
    Join Date
    Dec 2003
    Posts
    332
    Points
    3,271
    Level
    13
    Directivity of an antenna is mainly related to its radiation pattern, and is defined as the maximum power intensity radiated in a certain direction devided by the power intensity radiated by an isotropic antenna in that direction.
    While gain of the antenna is the directivity (in dB) minus the losses in the antenna (in dB). These losses are mainly due to ohmic losses if the antenna is a metal antenna, and due to mismatch between antenna input impedance and feed line impedance.
  5. #5
    Advanced Member level 1
    Points: 5,146, Level: 16
    sergio mariotti's Avatar
    Join Date
    Dec 2003
    Italy
    Posts
    468
    Points
    5,146
    Level
    16
    I agree edf and adel_48.
    Just add that usually directivity is simple to measure while gain isn't. So, often, commercially speaking, who sell is inclined to speak about "gain" instead "directivity". Of course, gain is lower than directivity.
