+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Member level 3
    Points: 436, Level: 4
    Join Date
    Jul 2015
    Posts
    54
    Points
    436
    Level
    hfss radiation boundary clarification
    I have some questions about radiation boundary I want to clarify,
    1) How long should the radiation boundary extend?
    I have heard it should be 1/4 of wavelength.
    If so, which is the correct way to implement?
    Click image for larger version.
    1/4 wavelength height and start at position 0 (bottom, ground plane)
    This makes my radiation pattern like this:
    you can see that the bottom of the radiation pattern is cut off, I think due to the radiation boundary assignment..
    1/4 wavelength height above and below, start at position of -1/4 wavelength (i.e not from 0)
    I notice that this option makes the resonant frequency lower than option 1..
    2) Which sides of the radiation box to assign as radiation boundary?
    is it: all faces except the bottom (ground plane) or all faces (including the bottom) except the face the port is on?
    •   Alt18th September 2015, 04:57
      advertising
  2. #2
    Member level 2
    Points: 1,340, Level: 8
    Join Date
    May 2012
    Posts
    49
    Points
    1,340
    Level
    8
    Re: hfss radiation boundary clarification
    lambda/4 distance should be applied to all sides of structure. this ensures absorption of signals at boundary with minimal reflection. you can always increase more than lambda/4 but simulation time increases as well.
    there's a change in resonant frequency as the E-field could be disturbed by reflections off the boundary, since the port is directly placed at the same plane as boundary.
    Increase all sides to at least lambda/4. Then try increasing further and there should be minimal or no change in resonant frequency.
    Best of luck
    1 members found this post helpful.
