Design Compiler To RTL Compiler scripts conversion
mangalji
Newbie level 5
Is there any way to use Synopsys DC commands and DC scripts in Cadence RTL Compiler ? Any utility that performs literal transition of DC scripts into RC scripts, will be helpful.
I doubt if such a things exists (to be given away for free). Please enlighten us here if you stumble across such a tool/utility.
I am afraid you might have to write it manually for Cadence RTL Compiler.
I had a similar issue in the near past when I was synth a design for FPGA. I had a synth TCL script ready to be used in Synposys Synplify. But for some reason I didn't have the Synplify tool at my disposal. Instead I had Mentor Precision Synthesis tool. So I had to create a new script that could use Precision and would do the exact things the Synplify script was doing.
It wasn't a very easy task and at the same time wasn't too complicated. I was juggling through the command_reference_manuals of both tools and adapting the Synplify commands for Precision. All it takes is a thorough understanding of the available commands for one tool and then finding out a similar command in the other tool.
All the best! :)
