+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 6
    Points: 3,542, Level: 13
    Join Date
    Oct 2006
    Posts
    333
    Points
    3,542
    Level
    13
    Microcontroller Integration to Flyback converter
    hi,
    i have just finished a 20 watt fly-back converter with wide input range 130 to 700 DC input by following http://www.onsemi.com/pub_link/Collateral/AN1327-D.PDF application note.
    Is it possible to add a small micro controller at the output side (which is isolated) to adjust the output voltage by using up down buttons or by using commands through RS232?
    •   Alt12th August 2015, 11:02
      advertising
  2. #2
    Advanced Member level 5
    Points: 28,406, Level: 41
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    cambridge
    Posts
    5,954
    Points
    28,406
    Level
    41
    Re: Microcontroller Integration to Flyback converter
    yes you can adjust the output voltage...make the tl431 an opamp error amplifier instead, and feed it a reference voltage (as is normal for error amplifiers of smps)...then just change the reference voltage to suit what output voltage you want....change the ref voltage by eg dac, or digital pot, or switchable resistive divider etc etc....micro can initiate change of ref voltage
    1 members found this post helpful.
