+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Member level 3
    Points: 436, Level: 4
    Join Date
    Jul 2015
    Posts
    54
    Points
    436
    Level
    Can you find these footprints?
    Hi everybody,
    I'm pretty new to pcb design, so footprints are a new concept to me.
    So far I know that a footprint for a component is described by the packaging/case (e.g 0402 for a capacitor). But how about for things like switches and connectors?
    Could anyone tell me what the footprints of the following components are?
    Thanks!!
    •   Alt5th August 2015, 03:38
      advertising
  2. #2
    Full Member level 4
    Points: 1,600, Level: 9
    Join Date
    Aug 2014
    Buenos Aires, Argentina
    Posts
    205
    Points
    1,600
    Level
    9
    Re: Can you find these footprints?
    What software are you using? Every PCB design software have different names for their integrated components footprints, unfortunately.
    You will have to look for them one by one (or using the "search" tool), modify one, or create your own ones.
  3. #3
    Member level 3
    Join Date
    Jul 2015
    Posts
    54
    Points
    436
    Level
    I am using altium software but I can't find even what type of footprint these components have so I don't really know what name to look for under..
    •   Alt5th August 2015, 05:19
      advertising
  4. #4
    Member level 5
    Points: 643, Level: 5
    Join Date
    Jun 2015
    Bangalore
    Posts
    86
    Points
    643
    Level
    If you don't have footprints in your software, you can create them add them to library. Their is some specific rule under IPC for naming. You can check that. or else you can put your own suitable footprint name.
    •   Alt5th August 2015, 07:09
      advertising
  5. #5
    Advanced Member level 2
    Points: 3,813, Level: 14
    Join Date
    Nov 2013
    Posts
    510
    Points
    3,813
    Level
    14
    The fundamental skill in any PCB design is creating footprints, you NEED to learn this, and actually in Altium it is usually very easy (You will come to hate the way some datasheets dimension things).
    Seriously, I create my own footprints even for so say standard parts, D2PACK mosfets for example are highly variable even within a single manufacturer and a stock footprint is usually not optimum, but even 0603 passives vary more then you would expect.
    Connectors, you tend to end up creating yourself, same for many switches, it is just part of the game.
    For standard packages the IPC footprint wizard makes it easy, for connectors and weird things you just got to learn how to draw (for some rotary switches, and circular connectors, radial grids are your friend).
    It is usually quicker to create a footprint then it is to post on a forum looking for one and then check that what you get is correct.
    BTW: Those switches will fit in a DIP8 footprint, should be easy to create, and that pin header is a simple SIP part on a 0.1 inch grid, the horribly expensive BNC you will have to create.
    Regards, Dan.
  6. #6
    Advanced Member level 5
    Points: 12,048, Level: 26
    Achievements:
    7 years registered
    Join Date
    Feb 2010
    UNITED KINGDOM
    Posts
    1,914
    Points
    12,048
    Level
    26
  7. #7
    Junior Member level 1
    Points: 88, Level: 1
    Join Date
    Jul 2015
    Posts
    15
    Points
    88
    Level
    if you once create the footprint,you will find that creating footprint is very simple.
    there are a lot of tutorial on the web ,so i suggest that you have better do it by youself,
    Some one says that one's life only need to do one thing is enough, so my thing is focus on hardware design and pcb layout.
  8. #8
    Advanced Member level 3
    Points: 6,313, Level: 18
    Achievements:
    7 years registered
    Join Date
    Sep 2009
    Lancashire UK.
    Posts
    932
    Points
    6,313
    Level
    18
    Go to pcblibraries.com and download their free tool to make them.
    Not that you should need it - these are simple footprints, take the time to learn to make them.
    Before you ask - have you searched the forum? Have you searched Google? - Please do so.
    Please do not ask me in private - ask in public. Also please do not ask me to be a forum friend.
    If I have gone to the effort to help you etc then please have the decency to at least acknowledge it and do not just ask a question then never come back..
    •   Alt5th August 2015, 21:33
      advertising
  9. #9
    Advanced Member level 1
    Points: 2,633, Level: 11
    Join Date
    May 2013
    Posts
    405
    Points
    2,633
    Level
    11
    Quote Originally Posted by Mattylad View Post
    When you get used to making your own footprints, it will be a much faster and less frustrating solution than spending unpredictable amounts of time to searching existing libraries for footprints.
  10. #10
    Achievements:
    7 years registered
    Join Date
    Feb 2010
    UNITED KINGDOM
    Posts
    1,914
    Points
    12,048
    Level
    26
    This is a tool to help you make footprints that are compliant to IPC-7351, much better to learn and follow what is now pretty much the industry standard in footprint design, so you are not searching libraries but getting an application that will do a lot of the mundane work for you in designing PCB footprints.
