junior_hpc
Newbie level 1
Hello. I'm trying to write my first program in JHDL (Java) for my Xilinx Artix 7 ac701.
The program must switch on a LED by pressing a button on my FPGA.
First I write my Java code. In the Java code I define an input named a and one output named led. The method on() has to switch on the LED by setting to 1 the output led.
After that I generate the netlist with JHDL and I obtain the following netlist (.edn):
After that I create on Vivado 2015 a new post-synthesis project and I import the .edn file previously generated and I create a new constraint file (.xdc):
The problem is when I try to generate the bitstream with Vivado because I get the following error:"[Place 30-494] The design is empty".
Resolution:"Check if opt_design has removed all the leaf cells of your design. *Check whether you have instantiated and connected all of the top level ports."
Do you have any idea where I am wrong? Well, I know how to do it in VHDL with Vivado, but I cannot figure out what's wrong with JHDL.
Thanks in advance.
Code Java - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 import byucc.jhdl.base.*; import byucc.jhdl.Logic.*; public class LEDon extends Logic { public static CellInterface[] cell_interface = { in("a", 1), out("led", 1) }; private Wire a, led; public LEDon(Node parent, Wire a, Wire led) { super(parent); this.a = connect("a", a); this.led = connect("led", led); } public void on() { if (a.get(this) == 1) { led.put(this, 1); } } }
Code - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 (edif LEDon (edifVersion 2 0 0) (edifLevel 0) (keywordMap (keywordLevel 0)) (status (written (timeStamp 2015 7 31 10 35 28) (program "BYU-CC's JHDL-EDIF netlister by Peter Bellows and Eric Blake" (version "0.3.46-internal-development")))) (library LEDon (edifLevel 0) (technology (numberDefinition (scale 1 (E 1 -12) (unit CAPACITANCE)))) (cell (rename ibuf "ibuf") (cellType GENERIC) (view view_1 (viewType NETLIST) (interface (port i (direction INPUT)) (port o (direction OUTPUT)) ) )) (cell (rename obuf "obuf") (cellType GENERIC) (view view_1 (viewType NETLIST) (interface (port i (direction INPUT)) (port o (direction OUTPUT)) ) )) (cell (rename LEDon "LEDon") (cellType GENERIC) (view view_1 (viewType NETLIST) (interface) (contents (instance a_IBUF (viewRef view_1 (cellRef ibuf))) (instance led_OBUF (viewRef view_1 (cellRef obuf))) (net (rename led_OPAD_OUT "led_OPAD_OUT") (joined (portRef o (instanceRef led_OBUF)))) (net (rename a_IPAD_IN "a_IPAD_IN") (joined (portRef i (instanceRef a_IBUF)))) (net (rename led "led") (joined (portRef i (instanceRef led_OBUF)))) (net (rename a "a") (joined (portRef o (instanceRef a_IBUF)))) ) )) ) (design ROOT (cellRef LEDon (libraryRef LEDon))) )
Code - [expand] 1 2 3 4 5 set_property LOC M26 [get_ports led] set_property LOC T5 [get_ports a] set_property IOSTANDARD LVCMOS33 [get_ports a] set_property IOSTANDARD LVCMOS33 [get_ports led]
Thanks in advance.
