need verilog/vhdl code for 7-seg display spartan-3 fpga
begging forum members for code isn't going to work very well. That might work on other forums, but on this one you ask targeted questions to get help when you get stuck and can't solve your problem with google.
Besides if you search this forum you will FIND 7-seg display code, which means you haven't even done any kind of search.
Hi, it's simple code for 1 digit diplay 7-seg.
Code Verilog - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_unSIGNED.ALL;
entity seg is
port (
                    SS2_A,SS2_B,SS2_C,SS2_D,SS2_E,SS2_F,SS2_G : out std_logic;
               SS1_A,SS1_B,SS1_C,SS1_D,SS1_E,SS1_F,SS1_G : out std_logic;
                    SW : in std_logic_vector(3 downto 0)
end dc;
architecture Behavioral of dc is
signal q:std_logic_vector(3 downto 0);
signal DISP1:std_logic_vector(6 downto 0);
begin
q<= SW;
seg1: process (SW)
   case q(3 downto 0) is
   when "0000" => DISP1 <= "1111110"; --0
    when "0001"=> DISP1 <="0110000";--1
    when "0010"=> DISP1 <="1101101";--2
    when "0011"=> DISP1 <= "1111001";--3
    when "0100"=> DISP1 <="0110011" ;--4
    when "0101"=> DISP1 <="1011011";--5
    when "0110"=> DISP1 <=  "1011111";--6
    when "0111"=> DISP1 <="1110000";--7
    when "1000"=> DISP1 <="1111111";--8
    when "1001"=> DISP1 <="1111011";--9
    when "1010"=> DISP1 <="1110111";--A
    when "1011"=> DISP1 <="0011111";--b
    when "1100"=> DISP1 <="1001110";--C
   when "1101"=> DISP1 <="0111101";--d
   when "1110"=> DISP1 <="1001111";--E
   when "1111"=> DISP1 <="1000111";--F
    when others => DISP1 <="1111111";
    end case;
SS1_A <=  DISP1(6);
SS1_B <=   DISP1(5);
SS1_C <=   DISP1(4);
SS1_D <=   DISP1(3);
SS1_E <=   DISP1(2);
SS1_F <=   DISP1(1);
SS1_G <=   DISP1(0);
END PROCESS;
end Behavioral;
FYI, the manufacturer of the board has sample designs, one of which is a 7-seg example.
