+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Points: 672, Level: 5
    Join Date
    Mar 2012
    Posts
    7
    Points
    672
    Level
    What is the cause of distorting in my circuit?
    I have the following waveform coming out of a MOSFET driver. As shown as red in the image. How do i go about cleaning up the signal without loosing the sharp rise/fall times? The very sharp rising/falling edges are important, which is why i don't want them to slow down.
    In this circuit, i have the output of the driver connected to the gate of an Nch MOSFET via an AC coupling capacitor, a zener (tying gate to source), a resistor (tying gate to source). The traces between each component lead is only a few millimetres long. The longest being from the AC coupling capacitor and the gate of the MOSFET, which is less than 20mm. What are the likely suspects to the cause the distortion?
    Also what is the cause of the spikes just before each transition? Is this just internal inductance of the driver?
    Click image for larger version.
    Thanks
    •   Alt17th July 2015, 17:43
      advertising
  2. #2
    Super Moderator
    Points: 57,436, Level: 58
    Achievements:
    7 years registered
    Awards:
    Most Frequent Poster 3rd Helpful Member
    Join Date
    Apr 2014
    Posts
    11,693
    Points
    57,436
    Level
    58
    Re: What is the cause of distorting in my circuit?
    it is unclear where in your described schematic you had the measurement points.
    It is also unclear what "distortion" you mean.
    Usually you don´t need an AC coupling capacitor.
    What driver are you using?
    --> show us your schematic and give timing information. (pulse duration = 0.5us? frequency about 1MHz?)
    If with "distortion" you mean the non horizontal lines in the red line:
    Then there are many sources for this:
    * bootstrap capacitor is loosing voltage (quite normal)
    * your scope probe is not adjusted
    * your scope probe GND is not good placed
    * your AC coupling capacitor generates this waveform
    The spikes before the transition should be caused by the driver input signals - at least in my eyes.
    All in all the waveform is not that bad.
    Klaus
    •   Alt17th July 2015, 18:22
      advertising
  3. #3
    Join Date
    Mar 2012
    Posts
    7
    Points
    672
    Level
    The measurement point is directly on the output pin of the driver with the ground as close to the driver as possible. The oscilloscope probe using a spring ground clip at the tip instead of a cable clip.
    The output of the driver is supposed to be a step between 0 and 12 volts. Distortion being overshoot and ringing. If the circuit was critically damped with no distortion the decay to 12 volts wouldn't exist.
    The AC coupling capacitor because gate driving signal is level shifted. Hence why i stated drain and source of the MOSFET with no voltages.
    The triangular wave in blue is the input waveform at 800kHz with a 50% duty ratio. The ringing on the input waveform is only seen when the driver and the MOSFET is turned on. By turning on the MOSFET, i mean applying a voltage across the drain-source. The ringing on the input waveform is only about half that seen here when only the driver is turned on. Previously, I have been applying square wave step inputs in to the driver via an FPGA source but i was curious about whether the driver was some form of analog amplifier or whether it operated like a Schmitt trigger - hard on, hard off - hence the triangular wave to drive such a device/circuit. As i'm attempting to figure out where the overshoot and ringing is coming from.
    The waveform is awful for my application. Once i sort this out, i want each pulse to have a width of approximately 5ns. Which, i currently can't obtain.
    •   Alt17th July 2015, 19:40
      advertising
  4. #4
    Advanced Member level 5
    Points: 35,340, Level: 45
    Join Date
    Mar 2008
    USA
    Posts
    5,665
    Points
    35,340
    Level
    45
    In any CMOS inverter, if you look close enough, you'll see
    such opposing-direction perturbations precede the output
    going in the eventual right direction. This is the Miller
    capacitance of the FET coupling the (say) L-H gate transition
    to the output, ahead of the eventual H-L drain transition.
    You also have that huge taper chain's shoot-through
    current and gate displacement currents banging the ground
    and the supply, and through the local decoupling one of
    those has a pretty strong dynamic effect on the other.
    All of that spike-ery bumping against the ground inductance
    to produce voltage spikes on the 'scope probe, by jacking
    the reference ground (but also the MOSFET driver's internal
    vs reference ground, the output will follow the on-chip
    ground which has additional wire bond inductance and is
    never as clean as board ground).
  5. #5
    Super Moderator
    Achievements:
    7 years registered
    Awards:
    Join Date
    Apr 2014
    Posts
    11,693
    Points
    57,436
    Level
    58
    Does this mean it decreases your applicationn's performance? Or does it just look awful?
    For the mosfet it should be no problem. The mosfet will be safely ON with maybe 8V so ringing around 11.5V to 12.5V won't change performance.
    Klaus
