+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 2
    Points: 102, Level: 1
    Join Date
    May 2015
    noida
    Posts
    Points
    102
    Level
    interface ARM controller (say STM32F4) to Internet
    Can you interface ARM controller (say STM32F4) to Internet using ethernet controller?
    If yes, tell me how will you do this?
    •   Alt13th July 2015, 14:58
      advertising
  2. #2
    Member level 2
    Points: 1,541, Level: 8
    Achievements:
    7 years registered
    Join Date
    Oct 2010
    Posts
    42
    Points
    1,541
    Level
    8
    Re: interface ARM controller (say STM32F4) to Internet
    I believe you you can do it. there are ethernet modules being sold for dirt cheap everywhere. For coding wise, this site and this site are two places i found dealing with ethernet and stm32f4.
    •   Alt13th July 2015, 15:31
      advertising
  3. #3
    Full Member level 3
    Points: 4,099, Level: 15
    Join Date
    Apr 2001
    California, USA
    Posts
    187
    Points
    4,099
    Level
    15
    STM32F4 needs a Ethernet PHY though. Otherwise you can use SPI ENCJ2860.
    •   Alt21st July 2015, 22:45
      advertising
  4. #4
    Administrator
    Points: 69,113, Level: 64
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    bigdogguru's Avatar
    Join Date
    Mar 2010
    Southwest, USA
    Posts
    9,832
    Points
    69,113
    Level
    64
    Blog Entries
    As a previous member indicated, if the particular STM32 device as an embedded Media Access Contorl (MAC) device, full implemenation of the Ethernet interface still will require an Physical Layer (PHY) device transceiver which acts as a bridge between the Link Layer (MAC) and the Physical Layer Media using one of several protocols including Media Independent Interface (MII), Reduced Media Independent Interface (RMII) or possibly Serial Media Independent Interface (SMII). A commonly used option is to utilize an external module with both the PHY device, such as a TI DP83848, Microchip LAN8720, STM ST802RT1A/B or Micrel KSZ8051MLL, the Magnetics (RJ45 Jack) and its own clock source typically (25MHz or 50MHz) depending on the protocol used.
    Many current microcontrollers support RMII, as it requires about half the number of I/O pins compared to MII, which doubles its clocking requirements to 50MHz compared to MII's clocking requirement of 25MHz.
    BigDog
    The Edge... there is no honest way to explain it, because the only people who really know where it is are the ones who have gone over.
    -- Hunter S. Thompson
    1 members found this post helpful.
