+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 4
    Points: 3,337, Level: 13
    Join Date
    Mar 2004
    UK
    Posts
    231
    Points
    3,337
    Level
    13
    Free or low cost GUI Development Software
    Hi Guys,
    I am working on temperature controller for home appliances automation. Using MSP430 as microcontroller. I wan to use touch screen and a facny type GUI for this project. Can i get ideas which software i should use to design/develop GUI and what touch LCDs i can use. The software should be either free or low cost.
    Thanks,
    Dani
    •   Alt6th July 2015, 13:13
      advertising
  2. #2
    Advanced Member level 5
    Points: 11,741, Level: 25
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    1,800
    Points
    11,741
    Level
    25
    Re: Free or low cost GUI Development Software
    is the gui dev and touchscreen sw reqd for a pc which controls msp430 or for msp430 alone ?
    •   Alt7th July 2015, 04:51
      advertising
  3. #3
    Full Member level 4
    Join Date
    Mar 2004
    UK
    Posts
    231
    Points
    3,337
    Level
    13
    srizbf,
    PC is not involved. I am looking for GUI library + software form embedded systems. Microcontroller used is MSp430.
    Any good suggestions?
    •   Alt8th July 2015, 10:55
      advertising
  4. #4
    Member level 4
    Points: 961, Level: 7
    Join Date
    May 2012
    Treviso Italy
    Posts
    68
    Points
    961
    Level
    7
    Hi Dani,
    uGUI written by Achim Dobler is a open source GUI in portable C and came with a good documentation in PDF format
    It seem easy to adapt for any MCU and any display type and size.
    I do not remember the download link but you can find it easily searching on the web.
    1 members found this post helpful.
  5. #5
    Super Moderator
    Points: 8,197, Level: 21
    Join Date
    Jun 2009
    Japan
    Posts
    1,056
    Points
    8,197
    Level
    21
    Hello!
    The problem with portable code is that the more it is portable, the less it is understandable.
    Myriads of ifdefs, etc. In case of a large color screen, yes, it makes sense to reuse a lot of
    existing code. But in case of (for example) a 128 x 64 black & white LCD. If you're using
    a MSP430, I guess you don't drive a VGA display but more likely a small size, probably
    black & white display. I think the best is to write your GUI yourself. It's not that hard, and
    you can quickly get something that works well and which is adapted to what you do.
    Dora.
    •   Alt12th July 2015, 04:10
      advertising
  6. #6
    Full Member level 4
    Join Date
    Mar 2004
    UK
    Posts
    231
    Points
    3,337
    Level
    13
    Thanks everyone.
    As per your posts, my previous experience and some search i have short listed following. Few of them are costly. Can anyone suggest some low cost options or even free.
    1. http://www.mikroe.com/visualglcd/
    Support mikroElektronika compilers only: mikroC, mikroBasic and mikroPascal, for all suported MCU architectures: PIC, dsPIC30/33, PIC24, PIC32, ARM and AVR
    2. http://www.embeddedlightning.com/ugui/
    Open Source GUI module for embedded systems
    3. http://ugfx.org/
    GFX is an embedded library for Displays andTouchscreens
    4. easyGUI: Embedded GUI Graphics Software
    5. https://www.segger.com/emwin-guibuilder.html
    Thanks.
