+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Junior Member level 2
    Points: 570, Level: 5
    Join Date
    Nov 2014
    Posts
    20
    Points
    570
    Level
    What is meant by Manhattan update rule in neural networks ?
    Could anyone explain me about
    1. What is meant by Manhattan update rule ?
    2. How to use Manhattan update rule in delta rule ?
    Thank you.
    •   Alt3rd July 2015, 06:41
      advertising
  2. #2
    Advanced Member level 5
    Points: 34,278, Level: 45
    Achievements:
    7 years registered Created Blog entry Created Album pictures
    SunnySkyguy's Avatar
    Join Date
    Sep 2007
    Richmond Hill, ON, Canada
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    Re: What is meant by Manhattan update rule in neural networks ?
    Been there.. But never tried it ;)
    http://www.helwan.edu.eg/university/...dnn_crf_MH.pdf
    it seems no delta on estimate just polarity.
    To converge the estimate STEP SIZE is incremented each time.
    seems like a simple but slow method but resilient
    like dynamic RAM Virtual Memory size reserve estimates.... Adapt with margin , grow by increasing larger steps at some rate until converge on desired value
    , stable, resilient , wide range
    not sure if step size reset to base increment on polarity toggle.. Probably
    A good design question lists your overall requirements™ The best question deserves a better answer. ™
    ... Tony Stewart EE since 1975
    •   Alt3rd July 2015, 07:05
      advertising
  3. #3
    Join Date
    Nov 2014
    Posts
    20
    Points
    570
    Level
    Even I too read that Pdf. But I didnt understand. If possible, can you explain me in short about Manhattan update rule.
    •   Alt3rd July 2015, 07:09
      advertising
  4. #4
    Achievements:
    Join Date
    Sep 2007
    Posts
    6,633
    Points
    34,278
    Level
    45
    Blog Entries
    7
    Ok , we both learned something
