+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Full Member level 1
    Points: 1,275, Level: 8
    deepsetan's Avatar
    Join Date
    May 2013
    Malaysia
    Posts
    113
    Points
    1,275
    Level
    8
    [Moved]: transconductance formula for transistor
    Hi guys,
    Can anyone explain to me what is the difference between this two transconductance formula?
    gm =UnCox + (Vdd/2 -Vtn)
    gm =2pi x gain-bandwidth x Cc
    •   Alt1st July 2015, 17:00
      advertising
  2. #2
    Newbie level 5
    Points: 751, Level: 6
    Join Date
    Jul 2013
    Posts
    8
    Points
    751
    Level
    Re: [Moved]: transconductance formula for transistor
    Actually, first one is a MOS transistor transconductance formula. And I think it is incorrect. it should be 2*Id/(Vgs-Vth) or sqrt (2*Un*Cox*Id). Second one is not gm of single transistor. This is probably effective gm of an amplifier and if Cc is compansation capacitor, it is probably a two stage miller opamp. In every situation, gm of a mos transistor is not equal to gm of whole amplifier. For example, if you have source degenerated stage, your effective gm is going to be gm/(1+gm*Rs), and gm that you mentioned in your post will be equal to this.
    Shortly, first one is gm of a mos (nmos because of Un), second one is effective gm of an amplifier. They are not same in every situation.
