+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 1
    Points: 1,013, Level: 7
    Join Date
    Jul 2013
    Posts
    34
    Points
    1,013
    Level
    7
    900 MHz collpits oscillator
    Hi RF Experts,
    Im a newbie to RF design, and here is my problem.
    Is it practical to design a 900Mhz collpits oscillator? well I have tried to reach that frequency but around f>300Mhz it starts to attenuate the amplitude.
    Does anybody know what the reason might be or if there is any frequency limitation?because I have searched alot but I couldnt find anything.
    I really appreciate your help.
    •   Alt20th June 2015, 13:28
      advertising
  2. #2
    Super Moderator
    Points: 46,805, Level: 52
    Join Date
    Apr 2011
    Minneapolis, Minnesota, USA
    Posts
    11,670
    Points
    46,805
    Level
    52
    Re: 900 MHz collpits oscillator
    Choose your L:C (or L:C:C) ratio so that it produces sufficient voltage swings, in view of the Amperes which are available to drive it.
    It is common for the inductor value to be between a thousand and a million times the capacitor value.
    A larger capacitor requires greater Amperes.
    A smaller inductor requires greater Amperes.
    Suppose your supply is under 10V. You might have a few mA travelling through your circuit. It should be possible to get a few V of swing at your LCC loop.
    (Now I'm cheating by using a simulator.)
    Therefore these are sample values which will yield 900 MHz:
    2 pF and 40 nH.
    3 pF and 23 nH.
    4 pF and 16 nH.
    This assumes resistor values in your circuit are under one kilohm.
    1 members found this post helpful.
  3. #3
    Member level 1
    Join Date
    Jul 2013
    Posts
    34
    Points
    1,013
    Level
    7
    Thanks for the reply. Here is the schematic of my design. In this design For C3 I use a 10p trim capacitor. I guess that the LC values are OK. but I don't know which resistor you mean? Would you please take a look at my design to see if I'm doing anything wrong?I got the idea of this schematic from a FM transmitter.
  4. #4
    Super Moderator
    Points: 239,598, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    2SC4367 has a typical transit frequency of 1 GHz (min. 600 MHz), so you're lucky if the circuit is oscillating at 900 MHz at all. You all want to use transistor with GHz bandwidth instead.
    Apart from this point, what's the value of C2? Is your circuit layout suited for 900 MHz at all?
    If you connected an antenna, it's frequency dependent radiation impedance may be sufficient to reduce the oscillator level with rising frequency or even stop oscillations. Similarly your measurement device (was is it) may have the same effect.
    B.t.w.: Are you reporting real measurements or a simulation?
    •   Alt22nd June 2015, 10:19
      advertising
  5. #5
    Member level 1
    Join Date
    Jul 2013
    Posts
    34
    Points
    1,013
    Level
    7
    I'm reporting real measurements. I don't have any problem with simulation since I have another oscillator design the works properly with simulation but in practice it doesn't even start to oscillate.
    If you are saying that the bandwidth gain is not suitable for my work (and I guess you are right because the datasheet says that too) then how come it is working over FM range (I was able to transmit a song using a microphone an receive it on a radio device).
    The Value of C2 is 68p. I used a perforated board and assembled the parts on it.
    I don't use an antenna and I use a 200MHz oscilloscope. I know that the frequencies doesn't match. But I think it should at least show the signal amplitude right.
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    Many problems:
    - the 1 GHz transistor will work well for oscillators up to several 100 MHz, it may even oscillate at 900 MHz, but probably not in your setup
    - a 200 MHz oscilloscope can't show correct signal amplitudes far above 200 MHz. It may indicate the existence of a signal at e.g. 500 MHz but hardly at 900 MHz.
    - I presume you are using a passive oscilloscope probe. It represents a large capacitive and lossy load to the oscillator which can well stop UHF oscillations, even of a better oscillator.
    - it's very difficult to make a 900 MHz circuit on a Veroboard without a massive ground plane.
  7. #7
    Member level 1
    Join Date
    Jul 2013
    Posts
    34
    Points
    1,013
    Level
    7
    I see what you are saying. I will make a PCB for test. And I will search for a GHz bandwidth oscillator. Do you have any idea how to test my circuit without the help of GHz oscilloscopes? Because I don't have access to one.
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,511
    Points
    239,598
    Level
    100
    Oscillator level can be tested with a schottky detector circuit.
    •   Alt23rd June 2015, 08:06
      advertising
  9. #9
    Member level 1
    Join Date
    Jul 2013
    Posts
    34
    Points
    1,013
    Level
    7
    Is it possible or I'm being delusional?
