+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Junior Member level 1
    Points: 375, Level: 4
    Join Date
    Nov 2014
    Posts
    16
    Points
    375
    Level
    S21 Floquet port in HFSS
    Hi everyone
    I've got a basical doubt in the way FloquetPorts are numerated in HFSS. My doubt is as follows:
    If I plot S(FloquetPort1:1,FloquetPort2:1). Am I plotting the S21 parameter of the TE mode or the S12 one??. I know that if you have a symmetric matrix that topic doesn't matter but it is not my case.
    Thanks in advance
    •   Alt17th June 2015, 10:24
      advertising
  2. #2
    Advanced Member level 3
    Points: 6,096, Level: 18
    Join Date
    Jun 2012
    Edmonton, Canada
    Posts
    953
    Points
    6,096
    Level
    18
    Re: S21 Floquet port in HFSS
    Quote Originally Posted by humFdz View Post
    Hi everyone
    Thanks in advance
    S12. Although there is no guarantee as to the polarization of the mode (that I am aware of).
    •   Alt17th June 2015, 15:54
      advertising
  3. #3
    Join Date
    Nov 2014
    Posts
    16
    Points
    375
    Level
    Quote Originally Posted by PlanarMetamaterials View Post
    If I suppose that the definition of the S12 is S(FloquetPort1:1,FloquetPort2:1).
    The definition of this parameter change if we use a wave port an a floquet port as stated in the pdf "Getting Started with HFSS:Floquet Ports" on page 27, where it is used the S(WavePort1:1, FloquetPort1:2) to define the parameter "S21" for TM mode (transmission for TM mode), where WavePort1:1 makes reference to the Tx port and FloquetPort1:2 to the Rx port
