Error Message With VHDL CODE
venkatpasumarthi
Newbie level 3
Code VHDL - [expand]
8
9
10
11
12
13
14
15
library ieee;
use ieee.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity comp is
port(a : in std_logic_vector(7 downto 0);
      y : out std_logic_vector(7 downto 0));
end comp;
architecture dataflow of comp is
  signal temp: std_logic;
begin
y<=  not(a) + "00000001";
end dataflow;
and it is showing the error
** Error: D:/modelsim_projects/2scmpliment.vhd(13): No feasible entries for infix operator "+".
std_logic_vector isn't a numeric data type. No arithmetic operations defined for it. You can use unsigned type instead Or use the non-IEEE library std_arithmetic_unsigned. Or apply type casts like
y<=  std_logic_vector(unsigned(not(a)) + unsigned("00000001"));
