+ Post New Thread
Results 1 to 16 of 16
  1. #1
    Full Member level 6
    Points: 2,299, Level: 11
    Join Date
    Mar 2013
    Posts
    322
    Points
    2,299
    Level
    11
    generate isolated dc-dc converter for gate drive
    hello guys
    i want to use a mosfet as a high side switch ( instead of a relay)
    there is no fast switching (of duty cycle) just 0 or 1 , just ON/OFF each couple of seconds .
    to turn on the high side mosfet , you need about 12-15v between gate and source .
    but i am using a micro-controller or a key button (digital pin NO PWM), so i need a circuit that can take 3-24v and transform that into isolated 15v . (very low current , 10-50mA)
    i have disassembled a solid state relay with similar specification and i cannot on earth under stand the circuit they are using , i have drawn it (if anybody want to investigate i can post)
    basically it uses 3coil transformer and an RC + transistor to transform any input DC voltage into AC (+/-2v) then past it to transfomer to create +/-12v signal then rectifies and some staff to drive the mosfet
    i am thinking if there is easier way to do it . using 555 timer + transformer ? maybe or a small dc-dc conveter ?
    note that most gate drivers are not for this type of applications, since they need switching and separate supply.
    i want a reliable , easy method , price is not an issue .
    what is your opinion
    thanks in advance for help
  2. #2
    Full Member level 4
    Points: 1,901, Level: 10
    xenos's Avatar
    Join Date
    May 2015
    Posts
    212
    Points
    1,901
    Level
    10
    Re: generate isolated dc-dc converter for gate drive
    You have a number of posible solutions available, some of them that I can quickly recall:
    a) make the power supply levels you require (resistors, capacitors) and use
    a1) optocoupler (eg 4N26) to control fet gate by mC
    a2) pnp bipolar transistor to control it
    b) use PVI5050 (isolated voltage generator for fet driving) - no other power source required
    c) use an isolated dc-dc converter 1W module: RY-2405 or equivalent
    1 members found this post helpful.
    •   Alt5th June 2015, 20:11
      advertising
  3. #3
    Super Moderator
    Points: 241,468, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,906
    Points
    241,468
    Level
    100
    What's your problem with the circuit, it's rather straightforward.
    1. A self-oscillating flyback converter
    2. A transistor to speed up switch-off operation
    The diode in parallel to the transistor is a zener (e.g. 12 V) that keeps the gate voltage constant over input voltage variations.
    From the options listed by xenos I would prefer the photovoltaic opto coupler if switching speed and isolation are sufficient. A recent type with good switching behaviour is e.g. Vishay VOM1271.
  4. #4
    Advanced Member level 5
    Points: 13,005, Level: 27
    Join Date
    May 2015
    Melbourne, Australia
    Posts
    2,213
    Points
    13,005
    Level
    27
    You can buy a ready made 5v to 12v isolated power module.
    There are quite small, cost around $15 and are readily available (sometimes on e-bay).
    Here is an example of the type of thing:
    http://www.homanndesigns.com/store/i...roducts_id=106
    Cheers, Tony.
  5. #5
    Full Member level 6
    Join Date
    Mar 2013
    Posts
    322
    Points
    2,299
    Level
    11
    Quote Originally Posted by FvM View Post
    it is that straight forward to you my friend ? :p , i have been shaking my head around it for several hours!! the thing that i cannot under stand is the transformer , usually there is primary and secondary , how is the third coil connected is puzzling me , can u provide more information or an application note for more clarification. or a datasheet for similar transformer
    thank u very much
    •   Alt6th June 2015, 10:02
      advertising
  6. #6
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,906
    Points
    241,468
    Level
    100
    The problem may be that classical electronic circuits like the simple one-transistor blocking oscillator aren't taught any more today, people apparently can't think of making an electronic circuit without an "IC", e.g. a 555. http://en.wikipedia.org/wiki/Blocking_oscillator
    •   Alt6th June 2015, 10:22
      advertising
  7. #7
    Full Member level 6
    Join Date
    Mar 2013
    Posts
    322
    Points
    2,299
    Level
    11
    just a question , this type of circuit needs a pulse transformer ? or audio transformer
    i really have a hard time choosing , espically such transformer with 3 winding of different number of turns :(
    usually available are center tapped example 1:1:3 , and such
    please help me with how to design such circuit and find a suitable transformer
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,906
    Points
    241,468
    Level
    100
    A transformer is a transformer. Audio, pulse, etc. are just applications involving a number of typical design parameters.
    I won't expect a ready made transformer fitting the application, but not impossible. Manufacturers like Coilcraft, Wuerth have a number of small catalog transformers, some may fit. Otherwise there are transformer construction kits helping you to make your own.
    I would try determine the parameters of the original transformer like windings ratio, primary and leakage inductance, DC resistance, saturation flux. If not available, redesign the circuit and try to find suitable tarnsformer parameters by calculation and/or empirical tests (or call it trial and error method). You probably end up with different parameters than the original design, no problem as long it's working.
  9. #9
    Full Member level 6
    Join Date
    Mar 2013
    Posts
    322
    Points
    2,299
    Level
    11
    thank u for your generous reply , if Switching speed and output voltage (8v for vom1271 , i have tested it , around 20ms to turn on ) is not enough . is a small isolated 5 to 12v dc dc converter suffcient for the job? or is there any problems with such choice , since the price is tempting (4$) . (assembling a circuit is much more expensive and time consuming)
    thanks again .
  10. #10
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,906
    Points
    241,468
    Level
    100
    Sounds like a really big FET. Specified ton with 200 pF gate capacitance is 50 µs. But I agree that the solution may be insufficient for some applications.
    Do you intend to apply the input signal directly to the DC/DC converter? I fear, the response time with an industry standard DC/DC converter could be larger than 20 ms. If response time matters, you'll go for a permanent driver supply through DC/DC and an optocoupler for the control signal.
    Yes, unfortunately.
  11. #11
    Full Member level 6
    Join Date
    Mar 2013
    Posts
    322
    Points
    2,299
    Level
    11
    Yes, unfortunately.
    It is indeed a big fet with approximatly 1000nC total charge and Input Capacitance of 30,000pF !
    my calculation for gate drive requirment : i=dq/dt ; for q=1000nC , ton=1ms , i=1mA ; and according to i=C*dv/dt
    i= 30000*10^-12*(12v/1ms)=3.6*10^-1mA . my humble calculations i found that 1mA is enough to turn on this fet in 1ms
    The response time is the delay after the output becomes stable ??, does this affect the rise time of the mosfet ?
    my application is not that sensitive , it is ok if the open/close switch order is delayed . but the mosfet should open quickly , because if fear if the mosfet is taking 5ms to 20ms to turn on; during this time it is NOT in the saturation region and it is half open so i fear it will get heated up quickly and destroyed by the load current (load is a motor 36v 100A pump) ! please correct me if i am wrong . the switching ON/OFF will occur every 10seconds , so it is very very very slow .
    i posted a schematic please take a look and comment
  12. #12
    Join Date
    May 2015
    Posts
    2,213
    Points
    13,005
    Level
    27
    This is way to do it.
    Cheers, Tony.
  13. #13
    Points: 13,342, Level: 27
    schmitt trigger's Avatar
    Join Date
    Apr 2013
    C4E4DEEEDCE6ECD2
    Posts
    2,245
    Points
    13,342
    Level
    27
    I advise people to build simple "joule thief" circuit for them to get acquainted with this basic -yet very effective- topology.
    EVERYONE is amazed at the performance of such a simple circuit. They can't believe one doesn't require the latest digital IC to build something useful.
    For a while I've been toying with the idea to suggest to this website's administrators to change the name of the "Tubes and Retro" forum to "Tubes, Retro and Discrete Component". I am sure that forum would get many more entries.
  14. #14
    Full Member level 6
    Join Date
    Mar 2013
    Posts
    322
    Points
    2,299
    Level
    11
    Quote Originally Posted by Warpspeed View Post
    is this reply for me ? , you mean according to FVM instructions my circuits is correct ?
    thanks
    •   Alt19th June 2015, 16:57
      advertising
  15. #15
    Join Date
    May 2015
    Posts
    2,213
    Points
    13,005
    Level
    27
    Sorry I was not more clear.
    I agree with FvM, use a dc/dc converter that runs all the time to generate a constant isolated supply, then use an opto coupler to switch your mosfet gate.
    It will allow very fast clean switching without any problems.
    Cheers, Tony.
  16. #16
    Full Member level 6
    Join Date
    Mar 2013
    Posts
    322
    Points
    2,299
    Level
    11
    for others who might be interested in the same subject i found an article that summaries a lot of what have been mentioned here : http://sound.westhost.com/articles/mosfet-relay.htm
    thanks all for help , i got it to work perfectly now , will mark as solved
