+ Post New Thread
Results 1 to 6 of 6
7th March 2005, 01:28 #1
- Join Date
- Mar 2005
- Location
- Alexandria, Egypt
- Posts
- 44
- Helped
- 2 / 2
- Points
- 1,669
- Level
- 9
Encoders
What is the diffrence between the priority Encoder and the normal encoder ? Plzz if any one can reply I will be thankfull. Also give me the number of an encoder without priority.
Thnx
7th March 2005, 10:07 #2
Re: Encoders
Originally Posted by Haytham-Sief
if (cond [0] == 1)
q <= 1;
else if (cond [1] == 1)
q <= cond [1];
else
q <= 0 ;
The h/w equailvalent will be such that cond[0] if top priority ..if it is one then it does not matter if cond[1] is 0 or 1 ... the implementation is usally in a layered mux condition.
1 members found this post helpful.
7th March 2005, 10:21 #3
- Join Date
- Feb 2005
- Posts
- 93
- Helped
- 12 / 12
- Points
- 2,224
- Level
- 10
Encoders
When you want to implement a priority encoder in VHDL/Verilog you use the if-else statement. The higher the priority the lower the delay. For normal encoders you use the case statement.
7th March 2005, 11:02 #4
- Join Date
- Mar 2005
- Location
- Alexandria, Egypt
- Posts
- 44
- Helped
- 2 / 2
- Points
- 1,669
- Level
- 9
Re: Encoders
Thanx very much for ur help but plzzz I need more explaination , I'm not using VHDL I'm using hardware without controling I mean I cant conrol the priority of the encoder. Thnx alot
7th March 2005, 12:33 #5
- Join Date
- Feb 2005
- Posts
- 93
- Helped
- 12 / 12
- Points
- 2,224
- Level
- 10
Re: Encoders
If you are using schematics then I uploaded you two pictures of a priority and a normal encoder examples.
In priority encoder x2 has the highest priority while x0 has the lowest one.
In parallel all have the same priority.
Hope it helps
6th February 2009, 16:26 #6
- Join Date
- Jan 2009
- Posts
- 38
- Helped
- 1 / 1
- Points
- 926
- Level
- 6
Re: Encoders
It is very useful. Thanks for your sharing.
+ Post New Thread
Please login
