+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 2
    Points: 925, Level: 6
    Join Date
    Feb 2013
    Posts
    44
    Points
    925
    Level
    RF Amplifier GPRS Module sim900
    Hello.
    I need to amplify the RF signal of my telecommunications MODULE SIM900. My main problem is that it should be bidirectional, and the frequency range is about 500-2000MHz; and i have been looking for it but i goit not any solution.
    I HOPE YOU CAN HELP ME.
    Thanks!
  2. #2
    Advanced Member level 5
    Points: 25,889, Level: 39
    Join Date
    Nov 2001
    Earth
    Posts
    3,658
    Points
    25,889
    Level
    39
    Re: RF Amplifier GPRS Module sim900
    You would amplify incoming signal or transmitted signal ??
    •   Alt24th April 2015, 22:25
      advertising
  3. #3
    Member level 2
    Join Date
    Feb 2013
    Posts
    44
    Points
    925
    Level
    Quote Originally Posted by BigBoss View Post
    Both at the same time, i just need like a "Black Box" with a SMA input - SMA Output and DC connection, no more.
  4. #4
    Join Date
    Nov 2001
    Earth
    Posts
    3,658
    Points
    25,889
    Level
    39
    Quote Originally Posted by Rikr09 View Post
    There is no such "blackbox" that amplifies the receiving and transmitting signals simultaneously between 500MHz-2GHz to my knowledge.You should make this module by using proper components.
    If you would, you can find many components ( LNA,PA,Switch etc.) to implement this module.
    •   Alt25th April 2015, 05:07
      advertising
  5. #5
    Member level 2
    Join Date
    Feb 2013
    Posts
    44
    Points
    925
    Level
    Thats I just has begun to do. Can you give me some idea like a block diagram with the parts which i have to take into account.
  6. #6
    Join Date
    Nov 2001
    Earth
    Posts
    3,658
    Points
    25,889
    Level
    39
    There are many components that amplify small signals and power signals in this band, no doubt.RFMD, Skyworks, MACOM, etc etc.. many suppliers have a large portfolio for LNAs and PAs.You will also need RF switch to commutate the antenna RX and TX mode. For switches Peregrine Semiconductors is the best one but the other manufacturers have low cost switches too.
    All you need to implement these component on a PCB with of course matching circuits, filters -if applicable- and surely power supply circuit(s). In order to implement such a TX/RX module, you can find very useful information on the internet.If you wait, I can propose a simple block diagram but you'd better to design your system by yourself for learning something.
  7. #7
    Member level 2
    Join Date
    Feb 2013
    Posts
    44
    Points
    925
    Level
    Off course i am woring on that but more ideas are better ... I ll be waiting for your block diagram. Thanks!!!
    •   Alt25th April 2015, 17:07
      advertising
  8. #8
    Points: 32,281, Level: 43
    Join Date
    Oct 2001
    Posts
    4,620
    Points
    32,281
    Level
    43
    SIM900 it is a GSM module for 800/900/1800/1900 MHz bands, so it will not work on other frequencies.
    http://wm.sim.com/producten.aspx?id=1019
    GSM its a half-duplex TDMA system, with RX and TX on different frequencies AND times. To boost both signals designing the amplifiers to meets all the GSM network regulations, is a challenge.
    Here you can find an idea of a block diagram for a system like this. The timing of switching between RX and TX is very important in a GSM system.
    http://www.qsl.net/n9zia/wireless/pdf/hyp-1.pdf
  9. #9
    Member level 2
    Join Date
    Feb 2013
    Posts
    44
    Points
    925
    Level
    Quote Originally Posted by vfone View Post
    Exellent data... I thought it was full duplex system.... I hve many information and with all these received form you, i will work with my partners and i will be notifying you. Thanks at all!
    Best regards,
    Ricardo R
