+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Advanced Member level 2
    Points: 3,401, Level: 13
    Achievements:
    Created Album pictures
    Join Date
    Dec 2013
    Sweden
    Posts
    562
    Points
    3,401
    Level
    13
    Swithing regulator loop stability & compensation.
    Hello.
    I have designed acircuit based on LTC3864, step-down dc/dc controller.
    I found out that Linear Technology has a power supply design program that contains my regulator so I have been exploring that and with encouraging results, kind of.
    The thing is I don't understand the following picture:
    Click image for larger version.
    I do get that the graphs are results from the loop compensation component values chosen, but facing the fact that I do not get what there suppose to do(I have read about it and the purpose seems clear but how and what different values matter where is another thing)
    Do you know why the phase respond is smooth up until 100kHz and the goes crazy?
    Seeing as this will be used to output 3-33V 0-3A I have to find some way of compensating the loop over the hole range but that does not seem possible, do you know?
    I can't manage to get the phase margin high enough and it gets to <10 at its smallest, do any one know what causes this and how to improve it?
    I'm flying blind.
    Sorry for the picture, I will upload full pictures asap.
    Here are the graphs of where I'm at now, the schematic page wont work but I'll get it somehow.
    •   Alt2nd April 2015, 12:03
      advertising
  2. #2
    Super Moderator
    Points: 241,537, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,932
    Points
    241,537
    Level
    100
    Re: Swithing regulator loop stability & compensation.
    Don't care about the phase near switching frequency and above. The system can't be described as time-continuous and analyzed with bode plot in this range. The results above 50 kHz are effectively meaningless for stability analysis.
    The basic problem is that you have no phase margin according to bode plot. Step response is respectively bad. You should have at least 40 degrees phase margin.
    •   Alt2nd April 2015, 12:05
      advertising
  3. #3
    Banned
    Points: 2,159, Level: 10
    Join Date
    Oct 2011
    Melbourne
    Posts
    159
    Points
    2,159
    Level
    10
    The step respsonse seems fine, indicating a reasonably stable system....
    •   Alt4th April 2015, 21:06
      advertising
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,932
    Points
    241,537
    Level
    100
    Yes, the updated loop gain and step response hasn't much to do with the original post.
