hi,
i created a 7X32 led matrix for text scrolling with the tutorial posted in Embedded Lab .com
MCU IS PIC 18F2550
CRYSTAL 20 MHZ
7 rows are scanned with cd4017 and goes to uln2803 and to matrix
32 columns are driven by chained 4 74hc595 shift registers
I can scroll text from right to left without any problem
I need help to
- scroll text from left to right
- scroll text vertically both upwards and downwards
-show some efects or animaions like fading,step in, sweep in etc..
-start scrolling from right end and stops at left end up to a defined time delay
-scroll one text vertically and others static mode
my code in mikroc is given below
 sbit Serial_Data at RA0_bit;
 sbit SH_Clk at RA1_bit;
 sbit ST_Clk at RA2_bit;
 sbit CD4017_Clk at RA2_bit;
 sbit CD4017_RST at RA1_bit;
const unsigned short CharData[][7] =
   {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00},   // 0x20, Space
   {0x04, 0x04, 0x04, 0x04, 0x04, 0x00, 0x04} ,  // 0x21, !
   {0x09, 0x09, 0x12, 0x00, 0x00, 0x00, 0x00},   // 0x22, "
   {0x0a, 0x0a, 0x1f, 0x0a, 0x1f, 0x0a, 0x0a} ,  // 0x23, #
   {0x04, 0x0f, 0x14, 0x0e, 0x05, 0x1e, 0x04} ,  // 0x24, $
   {0x19, 0x19, 0x02, 0x04, 0x08, 0x13, 0x13} ,  // 0x25, %
 {0x00, 0x00, 0x11, 0x0a, 0x04, 0x0a, 0x11},   // 0x78, x
   {0x00, 0x11, 0x11, 0x0f, 0x01, 0x11, 0x0e},   // 0x79, y
   {0x00, 0x00, 0x1f, 0x02, 0x04, 0x08, 0x1f},   // 0x7a, z
   {0x06, 0x08, 0x08, 0x10, 0x08, 0x08, 0x06},   // 0x7b, {
   {0x04, 0x04, 0x04, 0x00, 0x04, 0x04, 0x04},   // 0x7c, |
   {0x0c, 0x02, 0x02, 0x01, 0x02, 0x02, 0x0c},   // 0x7d, }
   {0x08, 0x15, 0x02, 0x00, 0x00, 0x00, 0x00}   // 0x7e, ~
  unsigned short Buffer[7][5] = {
                              {0,0,0,0,0},
                              {0,0,0,0,0},
                              {0,0,0,0,0},
                              {0,0,0,0,0},
                              {0,0,0,0,0},
                              {0,0,0,0,0},
                              {0,0,0,0,0}
unsigned int speed, StringLength;
unsigned short i, l, k, row, scroll, temp, shift_step=1;
unsigned short m, SerialConnect=0, UserIP = 0;
const unsigned char default_message[]="hello world";
void Send_Data(unsigned short rw){
 unsigned short Mask, t, num, Flag;
 for (num = 0; num < 5; num++) {
  Mask = 0x01;
  for (t=0; t<6; t++){
   Flag = Buffer[rw][num] & Mask;
   if(Flag=0) Serial_Data = 0;
   else Serial_Data = 1;
   SH_Clk = 1;
   SH_Clk = 0;
   Mask = Mask << 1;
  // Apply clock on ST_Clk
  ST_Clk = 1;
  ST_Clk = 0;
void scrollleft()
   StringLength = 11;//hello world
for (k=0; k> (7-Shift_Step));
     Buffer[row][3] = (Buffer[row][3] << Shift_Step) | (Buffer[row][2] >> (7-Shift_Step));
     Buffer[row][2] = (Buffer[row][2] << Shift_Step) | (Buffer[row][1] >> (7-Shift_Step));
     Buffer[row][1] = (Buffer[row][1] << Shift_Step) | (Buffer[row][0] >> (7-Shift_Step));
     Buffer[row][0] = (Buffer[row][0] << Shift_Step)| (temp >> ((7-shift_step)-scroll*shift_step));
   speed = 15;
   for(l=0; l
kindly help me to do above stated actions
sorry for my bad english and thanks in advance
